Online Now [2047]:
Visitors: 2047
Today: 79849
Total: 31037960
vibrate
ACS5_boy
PostPosted: Tue Mar 27, 2007 11:02 am    Post subject: vibrate Reply with quote
weiiii......tolong.
I got problem with my car. Got vibrate lorrr after I change my rubber clipper at longshaft. Any possibility longshaft bengkok??? The reason I change, my car shacking like hell when 80 to 100kmh. Mech said problem with my lower arm and rubber clipper. After I change Got vibrate pulak lorrr.......Any body can help???
rompers
PostPosted: Wed Mar 28, 2007 10:02 am    Post subject: Re: vibrate Reply with quote
Aiks..I tot this was common problem vibration from 80km - 100km means brakes haus??
pLeAse PImp mAh RidE!!
PostPosted: Thu Mar 29, 2007 1:34 am    Post subject: Re: vibrate Reply with quote
Rubber Clipper? Which part is that? okay same problem like mine when i got my E34. What i do?
1. Change Longshaft Coupling (Bushing)
2. Longshaft Centre Bearing (IMPORTANT)
3. Pray...
Once i done everything ok. BUT are you sure that your Longshaft problem?
Please also take a consideration to check tour Lower Arm Bar and Upper Arm Bar, if can, just change the whole assembly (arm bar and bushing together) rather then change the bushing only. Reason, after several years, the pressure (body weight and stress on the road) the arm bar, tak buleh tahan already... the steel might be softer dan tak mengenjal lagi. Some user want to budget just by changing the 'Bushing'. At the end, after several months koyak lagi.
Gud luck!
Weeii lama tak nampak..mana pergi lorr... main parachute lagi kerr...kekekekek..welcome back!
ACS5_boy
PostPosted: Thu Apr 19, 2007 9:31 am    Post subject: Re: vibrate Reply with quote
alamak.....your #3 make me laught laaa....
anyway thank you. Problem solved. My shaft bengkok and upper arm out. Shaft centre bearing also out.
Sikit bz lately. Tapi masih ada dan masih berparachute lagi. Mau join ka???
pssssttttt......high!!! "mengenjal"tu apa looorrrrrr?????????
PostPosted: Thu Apr 19, 2007 11:09 am    Post subject: Re: vibrate Reply with quote
macam spring lor....mmm how to explain mmm..okay kalo anu dalam spender, you kasi tarik seluar spender tuh, lepas tuh anu mengenjal keluar lor...kekekekek...
