Online Now [1332]:
Visitors: 1332
Today: 146104
Total: 31103628
mileage problem
hilmi
PostPosted: Thu Jan 18, 2007 2:12 pm    Post subject: mileage problem Reply with quote
attention to all MB sifus. my e30's mileage didn't work. all other indicators eg. tachometer, speedometer, temp., fuel, service lights etc. are working nicely. how do i overcome this problem?
PostPosted: Thu Jan 18, 2007 4:47 pm    Post subject: Re: mileage problem Reply with quote
maybe something wrong with the mechanical parts..u can check it out if u know how to open the meter
hilmi
PostPosted: Thu Jan 18, 2007 10:54 pm    Post subject: Re: mileage problem Reply with quote
tq bro. ada sapa2 tau apa mcm mau buka? hehe Laughing
PostPosted: Fri Jan 19, 2007 8:41 am    Post subject: Re: mileage problem Reply with quote
Tha problem with your tiny plastic gear piece (the one that rotate tha number). Do not simply open your meter unless you terrer giler pasang balik.
Last time in Motor Trader got service for this problem especially for BMW meter (E30) mileage rotor. I heard they charge somewhere around 200 to 300 bucks and also some guys mentioned the gear piece can get in Tamiya hobby shop (dunno whether true or not).
Anyone willing to help out here?
cheers!
joeleong
PostPosted: Fri Jan 19, 2007 3:47 pm    Post subject: Re: mileage problem Reply with quote
I have contacts for this problem , ring me up i'll check the price for you (012-2151555)
PostPosted: Fri Jan 19, 2007 6:38 pm    Post subject: Re: mileage problem Reply with quote
i too have the dreaded milage problem...
PostPosted: Sat Jan 20, 2007 1:46 am    Post subject: Re: mileage problem Reply with quote
Bro for you 'Must' have mileage problem wei... imagine, bawa kereta dari kuching sampai kl... mesti mileage gone crazy..heheheh.. ikut Laut China Selatan lagi..kekek
GURAU AH!
hilmi
PostPosted: Sun Jan 21, 2007 1:52 pm    Post subject: Re: mileage problem Reply with quote
tq joeleong. got ur no. will ring u later Very Happy
joeleong
PostPosted: Sun Jan 21, 2007 3:20 pm    Post subject: Re: mileage problem Reply with quote
No problem bro anytime Very Happy
PostPosted: Sun Jan 21, 2007 4:03 pm    Post subject: Re: mileage problem Reply with quote
tu lah....masuk air masa melintasi laut cina selatan...air cleaner i ok..
joeleong
PostPosted: Wed Jan 24, 2007 5:32 pm    Post subject: Re: mileage problem Reply with quote
Hey bro i had check the price for that roughly is about RM200-RM250
rompers
PostPosted: Thu Jan 25, 2007 12:54 am    Post subject: Re: mileage problem Reply with quote
uhh huhu....my meter even worst...only the temp and speedo workz, the rest got angin wan, sumtimes work, sumtimes don't... Trip meter don't talk larr, 23 year old car went only 98K klicks Embarassed Sad Crying or Very sad
pLeAse PImp mAh RidE!!
PostPosted: Thu Jan 25, 2007 1:16 am    Post subject: Re: mileage problem Reply with quote
disamble your meter, and pasang balik.
A fungus or any substance might build up due to our humidity, therefore the connection between your ECU and your dash meter was not correctly. Sometimes when your car in HOT SUN, when you drive OK, then when hujan or aircond blast, the meter not working.
At the back of your meter, ada SCSI (connector macam computer). These port ada banyak jarum halus and each represent power supply and other data sent by the ECU there will be Male & Female (Female will be on your meter).
Kadang2 these jarum (Male) kotor, the best way to clean;
1. Spray a WD40, leave it dry.
2. After dry, kasi bengkok itu jarum sikit
(this will tighten the connector)
3. Spray WD40 again and straight plug in your meter.
4. On engine and give a test drive.
5. If okay then you start mounting the meter back in its place.
Thats It.
Mine not working either, somehow i did that, not working already, together with mileage.
Note:
Mileage meter will work together with speedometer.
Mileage jalan speedometer mesti jalan.
Spedometer jalan mileage tak jalan, plastic gear rosak.
WOKEY
rompers
PostPosted: Thu Jan 25, 2007 11:30 am    Post subject: Re: mileage problem Reply with quote
Uih..complicatednyer. Bro, I never go university one lahand don't have the nimble fingers like you also. Nanti aku kasik bukak itu meter, hancur berderai. Nampaknyer kena beli meter half-cut jer lah Crying or Very sad
But thanks for the tips...maybe sebelum nak tukar, bule bikin eksperimen macam tu.... Laughing
PostPosted: Thu Jan 25, 2007 8:31 pm    Post subject: Re: mileage problem Reply with quote
highway u are right....
its is the plastic gear...
and yes i also heard can buy at the tamiya shop!!!
so weird...
and the last thing, there is one place fixing all these, that i know (besides joe's place) is in OKR
price - rm250...
price of a new 1/2 cut meter
so find out which is more worth it for oneself...
Smile
