Online Now [1171]:
Visitors: 1171
Today: 91641
Total: 31049752
[WTS] M-TECH 1 Steering for E30 and E34
PostPosted: Mon Jan 08, 2007 11:24 am    Post subject: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
RM300
need to rewrap
- 0126367197
PostPosted: Mon Jan 08, 2007 2:31 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
can fit into e21?
PostPosted: Mon Jan 08, 2007 3:40 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
dunno la...any sifoo can suggest?
BlackE34
PostPosted: Mon Jan 08, 2007 4:32 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
check bushing. bleh nya kot.
Started off with a Bimmer.... Ending Life with a Bimmer
PostPosted: Tue Jan 09, 2007 4:23 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
cannot fit E21 sorry
PostPosted: Tue Jan 09, 2007 9:50 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
hmmm...but sure can fit E30 E28 or E34 ehehhehe...correct me if i'm wrong:)
PostPosted: Wed Jan 10, 2007 4:29 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
you are right! Laughing
rompers
PostPosted: Wed Jan 10, 2007 8:35 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
Tapik diameter besar daripada yang biasa untuk e30 kan..kan?? Correct me if i'm wrong Smile
pLeAse PImp mAh RidE!!
PostPosted: Wed Jan 10, 2007 4:18 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
hahaha...sifoo can correct rompers or not hehehe
PostPosted: Thu Jan 11, 2007 6:16 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
diameter for E34 bigger than E30, BUT, recently i discovered, E30 yang besar pun ada (this is from E30 without Power Steering)
To know which product model that fits,
MTECH 1 Steering
Remove the centre BMW logo and check around the trim, it will stated for E34 or E30. but then again, the steering hub (the lubang lar) can fit E28/E30/E34.
Cheerio!
PostPosted: Thu Jan 11, 2007 6:23 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
if wanna fit e28 must retrofit, e28 like some what bigger...
like how they fix an e30 mtech2 steering on jezz 's e28...
rompers
PostPosted: Thu Jan 11, 2007 7:01 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
ohhh..gitu rupanyer...tenkiu tenkiu para sifoos kerana sanggup berkongsi
mafia
PostPosted: Fri Jan 12, 2007 1:13 am    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
found the steering shaft has been changed to the later model tht has the same spline as e30!
PostPosted: Fri Jan 12, 2007 5:16 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
roger that mafia man! Smile
PostPosted: Sun Jan 14, 2007 1:50 pm    Post subject: Re: [WTS] M-TECH 1 Steering for E30 and E34 Reply with quote
some additional info:
it it will fit all BMW E30 E34 M3 M5 E32 E24 E28 models...this steering has 380mm in diameter...or 15 inches laaa...
