Online Now [1233]:
Visitors: 1233
Today: 134681
Total: 31092792
painting ye valve cover
PostPosted: Thu Dec 07, 2006 5:13 pm    Post subject: painting ye valve cover Reply with quote
any pointers to give...??normal paint might peel i guess so fire away!!!
PostPosted: Fri Dec 08, 2006 3:55 am    Post subject: Re: painting ye valve cover Reply with quote
hehehe hahahha... valve cover? m20 or m40 lor?
some valve cover covered with ABS Plastic like M50 engine, therefore easy to paint. And some cheap spray aerosol paint claimed 'Heat Resistant' on which i think not.
Recipe
1. Heat Resistant Spray Paint
comes either red, silver or black. Get the BBQ pit paint.
2. Normal RM5.00 Paint
find your desired color code for your theme
3. Sand Paper or hand drill machine with Sanding cups
4. Wire brush (use with hand drill)
5. 1 bottle of spirit
6. Heat gun or Hair Dryer
7. Paint polish
8. Set of valve cover gasket
9. 1 tube of gasket sealant
How to do larr
1. Remove your valve cover and clean it with detergent Inside Out.
This is to remove your minyak hitam or any carbon stains
2. Wipe dry and place it direct sunlight
3. Start sanding (sand paper) or using wire brush with drill to clean or remove the stain/grease layer on top of your valve cover.
4. Wipe clean with water and leave it dry again.
5. Once dry, clean it with Spirit (get it at your local hardware shop). Please DO NOT USE THINNER because thinner got oily substance.
6. Once the spirit dry, cover your bottom valve cover to avoid paint particles. Once done, you can start spray your top cover layer by layer. If you wish to paint your cover white or bright colour, use SILVER Heat Spray Paint. If Dark color, use BLACK Heat Spray Paint.
This is to give base colour.
PAINT APPLICATION
Please paint using layering system. First layer, heat it with hair dryer or heat gun (heat until the valve cover is warm) and follow the same process on the second layer and so on. Heat Spray Paint contain 'Rubbery' compound that will stick to your paint surface when it heated.
7. Once the 'Heat Paint' fully cured, sand it mild (this is to make your next paint stick). Start spray with your 'RM5.00' paint in the same layer process BUT no sanding needed. Heat it with hair dryer/ heat gun per layer.
8. Once complete and fully cured, wax it one time. You can use your drill with sanding kit, to 'scrape off' the paint that covered the BMW lettering into chrome effect.
9. Carefully relocate your valve cover and SMILE!
THATS IT! HAPPY PAINTING AHHH
PostPosted: Fri Dec 08, 2006 12:40 pm    Post subject: Re: painting ye valve cover Reply with quote
pheeewwiiitttttttttttt cantiknyeeee
WakE30Panchur
PostPosted: Fri Dec 08, 2006 12:48 pm    Post subject: Re: painting ye valve cover Reply with quote
Kalu upah Highwaystar untuk cat valve cover tu berapa agaknya? Senang cerita tak payah nak explain panjang2. Setuju tak ambik tender tu Highwaystar?
SAMBK
PostPosted: Fri Dec 08, 2006 1:53 pm    Post subject: Re: painting ye valve cover Reply with quote
Greets,
Cool, memang CUN meleCUN, bro Highwaystar kan "artist", kan, kan,kan, hehehehehe.
Engine bay dier pung CLEAN giler, tak macam mine.
Baik punyer paint work, errrrrrrr, bole ke upah u cat mine also, FLAT BLACK kaukau.
Regards.
Shocked Shocked Shocked
*** 1988 E30 SEDAN ***
PostPosted: Fri Dec 08, 2006 2:32 pm    Post subject: Re: painting ye valve cover Reply with quote
wahhh highwaystar sooo terrer.....some more engine so lawa.....tanks man
PostPosted: Sat Dec 09, 2006 2:41 am    Post subject: Re: painting ye valve cover Reply with quote
wow wow wow .. nice one bro.. bro highway can paint almost everything mannn.. hahaha
boyhartge
PostPosted: Sat Dec 09, 2006 2:59 am    Post subject: Re: painting ye valve cover Reply with quote
waaa...kalu ini macam...sy mau jadi anak murid sifu highway bole???pllsssss
PostPosted: Sun Dec 10, 2006 7:57 am    Post subject: Re: painting ye valve cover Reply with quote
heheheh... guys, boleh takde hal. Upah? ish... dono lah wei...takde guarantee heheheh...
so far so good, but when you start your engine for the first time after placing your valve cover, it will smoke and smell burnt (this is due to paint resin melt when extremly hot)
schnitzsmo
PostPosted: Sun Dec 10, 2006 9:07 am    Post subject: Re: painting ye valve cover Reply with quote
waaaa...tabik tuan highway !!!
bro x pyh tembak clear coat ke ?
klu tmbak clear ape jd ??
ade crack x klau spray DIY ni ??
heheh...byk plak soalan aku...sori ar bro hiway psl wa mmg minat bab spray2 nie...
PostPosted: Sun Dec 10, 2006 10:50 am    Post subject: Re: painting ye valve cover Reply with quote
nak tembak clear coat pun okay. tapi gua suggest pakai kedai punya clear coat, sebab yang murah punya (RM5) spray tuh, gerenti tak tahan lama. infact kalo minyak itam tumpah ker ada marking. So, for those ppl out there, if you wish to have a clear coating on your valve cover, tolong pakai industrial clear coat. advantage...boleh polish kalo kotor. cheers!
schnitzsmo
PostPosted: Mon Dec 11, 2006 6:10 am    Post subject: Re: painting ye valve cover Reply with quote
thanx for the info bro...
PostPosted: Mon Dec 11, 2006 7:05 am    Post subject: Re: painting ye valve cover Reply with quote
glad that i can help. cheers guys! mmm...kalo dah buat, kasi lansi ahhhh...kekekeke
