Online Now [2616]:
Visitors: 2616
Today: 172940
Total: 31117046
My Engine does not fire
PostPosted: Sat Dec 16, 2006 2:54 pm    Post subject: Re: My Engine does not fire Reply with quote
i have m40 starting problem just like you.sampai toening berapa kali....turns out there is a faulty switch that kills ignition in your bglove compartment.go and check that.good luck
rezzy
PostPosted: Tue Dec 19, 2006 12:46 pm    Post subject: Re: My Engine does not fire Reply with quote
Today 19th Dec all my car parts are fixed then tried to start still no sign of firing. Check one after the other from coil,sparkplugs all seems not firing, then check my alarm system wiring, computer, still can'nt find any trouble then ask the staff to change the relay or what ever at the firewall the one at the side of petrol relay (white) in colour still no sign and off I cabut frustrated, Then I received a call saying that they found a wire damage under the fuse box at the engine bay (yet for me to see) I was wondering what wire burn or what tomorrow morning. he call the wireman to do it, I have told them use a proper wire connecter if any wire change no such thing as cut and joint wrap over like what many wireman did. Hope that is the problem at least I know what the actual problem but koyak probably 2K barang alone 1500plus. I did a top overhaul. I will update again after i get my car. If that is true I my pulley sensor means still good as it cost 250 now. Spare lah.
PostPosted: Tue Dec 19, 2006 2:15 pm    Post subject: Re: My Engine does not fire Reply with quote
changed my crank angle also no spark at the coil, or plug...it didnt work.....comes back to the little switch in the glove compartment.....and its still running till today.and i have a crank angle sensor good as new
rezzy
PostPosted: Wed Dec 20, 2006 8:02 pm    Post subject: Re: My Engine does not fire Reply with quote
At last I am satisfied and happy driving again today 20th Dec.
All was cause by an ageing car, there is a wire right underneath the fuse box located at the back of the glove compartment suppost to be the main wire that carry the electrical to the other supply of the engine such as coil, sparkplugs and others was burn or eaten slowly (lucky not on fire) as I had problems since Raya of and on I had starting problem lastly landed at home totally dead, was lucky not on fire. The wireman says of ageing it was heated main supply of current. he did the changing but I did not see but instructed to use proper connecter if any wires cut and join for safety.
After all done it fires and I had done my top overhaul gone $2400 all in all. I am happy got the root of the problem and thanks to all of you who in one way or another guided me in a way, so now my sensor pullay is still good and I have to keep as spare as was not that problem anyway. Very Happy
PostPosted: Thu Dec 21, 2006 1:02 am    Post subject: Re: My Engine does not fire Reply with quote
good to hear that bro rezzzy =) .. if I'm back to s'ban we go TT ok?
rezzy
PostPosted: Fri Jan 12, 2007 5:47 pm    Post subject: Re: My Engine does not fire Reply with quote
Call lah if you are around aRRrgghh why not.
Here come back with my car problem after running a few days start the starting problem again but still at home not elsewhere but I can start by cranking the starter and lastly totally can't start. Got the doctor again he clean up and check all conection it works again till today but I am still not happy and worry with it as I can smell like wire burnt smell when I stop and they say its the gasket glue smell but I am not happy and worry everyday, dare not drive out of Seremban and done over 500kms, now my next move is changing my whole fuse box including all the wiring loems as of the burn wires are under the box and melted the bottom and 1 off my relay also melt so I will not risk my car and wanted to change the box and see how it goes as its the heart of electricity supply. One of our members got one in KL from a chop shop at RM250 with all the wires together, hope it will works well as I see even when I on my small lights with the fog lights it is slow action not as before so I think something to do with the connection at the box. this is a lesson we learn from an ageing car bit by bit.
rompers
PostPosted: Sun Jan 14, 2007 7:03 am    Post subject: Re: My Engine does not fire Reply with quote
wa bro rezzy...you are very descriptive about the situation you are facing. That's extremely good and helpful to us, or at least to me, coz I'm still very much learning...
I hope you will continue to share your experiences trouble-shooting your car with us all here...Kudos and thanks again Bro Rezzy.
p/s - found out where to cekup all the containers already bro...thanks
pLeAse PImp mAh RidE!!
rezzy
PostPosted: Sun Jan 14, 2007 6:43 pm    Post subject: Re: My Engine does not fire Reply with quote
The car is still not perfact yet where electrical are concern so wait Monday I am going to the w/shop on the wiring problem.
rezzy
PostPosted: Mon Mar 19, 2007 3:21 am    Post subject: Re: My Engine does not fire Reply with quote
Back here after so long I was away and now its for everbody to learn thru what I have gone thru.
Now my car had been done and tested after I change my fusebox which really is the main problem where the bottom was eatten slowly and my guess was right, the burn smell was from there and a leason to my mech. its one in a million so I told him open one by one the joint conector to the box and replace it, wireman scared to do it so he did it himself I left my car to him and off to Jakarta for a week and ask him to use the car day and night and was okay. after all done my lights are britter and all function better, now I drive with confident day and night and my longest drive last week Wednesday to Friday I drove to Kuala Kedah for Langkawi back at night all the way reach Seremban at 1.45am consider daring juga I and I am happy with it. So wiring is hell to check millions of tinny wires in it, after driving all other cars back to my e30 is the best even I drove a C200 I still enjoy my e30 the best lah. I wii try to upload the picture of my fusebox soon as haven't taken pictures yet its still in my booth.
PostPosted: Mon Mar 19, 2007 3:32 am    Post subject: Re: My Engine does not fire Reply with quote
Abg rezzy, sure one heck of experience u have there! Glad that your ride is tip-top now. Thanks for sharing too =) .. E30, the best it is ..
rezzy
PostPosted: Sat Jul 19, 2008 7:23 pm    Post subject: Re: My Engine does not fire Reply with quote
Hey guys here sorry for not doing my homework here as promise that I will show pictures of the damage electrical fusebox and will load it soon. Too many sites to go thru and had been long not online here sorry just wait soooon ok.
