Online Now [1563]:
Visitors: 1563
Today: 75079
Total: 31186221
plug cable
boohtuck
PostPosted: Sun Nov 12, 2006 5:25 pm    Post subject: plug cable Reply with quote
plug cable
successful alwaysssss
boohtuck
PostPosted: Sun Nov 12, 2006 5:26 pm    Post subject: Re: plug cable Reply with quote
2 bro2....saya punya keta jerk jerk le....berapa RM 4 plug cable?
PostPosted: Mon Nov 13, 2006 1:29 am    Post subject: Re: plug cable Reply with quote
Bro, kalau jerking tak semestinya plug cable .. apa kata bagi mekanik check dulu.. idling valve ker.. AFM ker.. etc.
PostPosted: Mon Nov 13, 2006 7:43 am    Post subject: Re: plug cable Reply with quote
Maybe plug cable (jerking...loose power and backfire)... costing tak tau lagi, but do check along your cable... sometimes the cable cracked and oxidization occur and result corrosive inside the cable, see how big is the damage area, if small part only then cut and throw the damage area and sambung wrapped with electrical tape. this is temporary use only. after that cari sparepart kat potong kete.
cheerio!
reme28
PostPosted: Thu Mar 22, 2007 4:25 am    Post subject: Re: plug cable Reply with quote
dulu keta saya pernah jd mcm ni.api sparking out the wire.siap beli cable baru Sad rupa-rupanya bukan cabel tapi rotor distributor hancur.tukar baru terus ok.api pun tak sparking
PostPosted: Thu Mar 22, 2007 4:30 am    Post subject: Re: plug cable Reply with quote
you koreekkkk... yup betul tuh. distributor rotor also count.. sometime rotor arm pun ada effect. Thank reme!
reme28
PostPosted: Thu Mar 22, 2007 4:41 am    Post subject: Re: plug cable Reply with quote
y're welcome Very Happy
