Online Now [1905]:
Visitors: 1905
Today: 79755
Total: 31190897
OMG crazy rims
Go to page Previous  1, 2, 3, 4
PostPosted: Fri Jul 27, 2007 1:37 pm    Post subject: Re: OMG crazy rims Reply with quote
spacer can use...to convert pcd why not.but have to calculate the offset of your original rims, plus the new wheels, its width and the spacers, may ot for coz spacers have to be at least .85inch thicks to convert, have to have ample amount of metal to have strength integrity of the spacersn measure your bolt, n excess metal to be thick enuff like a rim hub,bolt have to be fush inside the spacer...ok?
abcd
PostPosted: Fri Jul 27, 2007 4:33 pm    Post subject: Re: OMG crazy rims Reply with quote
bro
the rim i keen is 15x6.5jj offset 25.
to fit my e30 (316i)
u think got problem finding suitable spacer as said above?
if ok, know which workshop i can get it done in JB (I in JB la)
thanks v much
PostPosted: Fri Jul 27, 2007 5:09 pm    Post subject: Re: OMG crazy rims Reply with quote
bro try to find a machine shop i'm sure they're lots of them in JB. i have used both metal and aluminium before on my other cars and nvr had any problem going on high speed. the metal one i did for the rear was rm125 ea. for 1.5" and the aluminum one was rm190 ea. for 1.5" also for the rear.
else try to check here for ref. : www.autoanything.com/s...510A1.aspx
search for "wheel spacer"
PostPosted: Fri Jul 27, 2007 5:42 pm    Post subject: Re: OMG crazy rims Reply with quote
abcd wrote:
bro
thanks v much
Bro abcd, why you want to use spacer? the offset and wheel size ngam with your E30...? unless the offset is 38 or 40 or more...mmm
PCD & OFFSET INFORMATION
MINI (NEW)
PCD 4x100 OFFSET 35 CENTER BORE/CONE 57.0
E30
PCD 4x100 OFFSET 15-25 CENTER BORE/CONE 57.0
E30 MOTORSPORT
PCD 5x120 OFFSET 18-20 CENTER BORE/CONE 72.5
E36, E46, Z3
PCD 5x120 OFFSET 35-42 CENTER BORE/CONE 72.5
E31, E32, E34, E38
E39
PCD 5x120 OFFSET 18-20 CENTER BORE/CONE 74
PostPosted: Fri Jul 27, 2007 5:48 pm    Post subject: Re: OMG crazy rims Reply with quote
this is a 25mm thick wheel spacer come with center bushing original from japan 100pcd - 100pcd Center bore dunno
Spacer RM300
abcd
PostPosted: Sat Jul 28, 2007 12:47 am    Post subject: Re: OMG crazy rims Reply with quote
abcd wrote:
bro
thanks v much
MINI (NEW)
E30
E30 MOTORSPORT
E36, E46, Z3
E31, E32, E34, E38
E39
Bro Highwaystar
many thks for your info. kam sia kam sia
offset is ngam ngam but I need to convert PCD of the rim i like (114.3) to fit my e30 (100) - thats y concern after adding spacer, think wheel will jut out of fender oredi rite?.....
another rim i eyeing also pcd114 but offset likely to be zero (owner not sure, wtf) so this one use spacer to push out and convert pcd shd be ngam ngam (hopefully)
need to research costs b4 decide which one to get la...
no money to afford the expensive bbs, hartge or alpina or ronals etc leh....
thanks Sad
PostPosted: Sun Jul 29, 2007 2:26 am    Post subject: Re: OMG crazy rims Reply with quote
I think kena mod mudguard fender la bro....maybe tak lepas kalau pakai spacer,kena lebar cam black e30 jas dlm lansi gallery,but if model 323 or 325 tapak roda lebih luas dari 320 rasanya...
abcd
PostPosted: Sun Jul 29, 2007 2:37 am    Post subject: Re: OMG crazy rims Reply with quote
Bro Bimmerasta
Sori I china and cant read malay.... can repeat in english?
thanks
PostPosted: Sun Jul 29, 2007 5:14 am    Post subject: Re: OMG crazy rims Reply with quote
Bro Bimmerasta
thanks
Opssss....sorry bro,
Ok let say u must modified your mudguard fender if u want use spacer coz wheel will jut out of fender like u said,must mod wide fender like pic...
My opinion 1st u must calculate the offset of your original rims plus the new wheels, its width and the spacers,it's can be ngam ngam if your body have big wheel space like 325 body but still must mod mudguard if your rim have big offset...
I think JB have many expert foundry/machine shop....bcoz many cars with extreme wide body & huge rims came from there!!! Twisted Evil
sorry with my broken english,hope u can get what i say... Wink
Malaysia Boleh!!!
Thanks...(fuh...berpeluh gak aku nak translate nih...)
PostPosted: Sun Jul 29, 2007 5:17 am    Post subject: Re: OMG crazy rims Reply with quote
Fuuh..then you have to use 114.3 - 100 spacer larr (on which thickness around 20-25mm) to use this spacer, you have to get rims atleast with the offset 45.... so 45 minus 20mm wll get 23 offset... mmmm guess so..
okay just say your sets of rims cost you average RM800 (without tyre)
Spacer will cost you another RM550 and Centerbore rings cost you another RM280 per set = total RM1630
If get rim for E30 with correct offset estimated RM1500 (2nd hand) an most probably you will add another 280 or less for center bore total of RM1780 (an extra of RM150 for comfortable and smoother ride)..
BUT ITS ALL UP TO YOU...kekekeeke
good luck!
PostPosted: Sun Jul 29, 2007 2:17 pm    Post subject: Re: OMG crazy rims Reply with quote
either machine the rims if theyre solid...or they're 6.5 j anyways.won t hurt if spacers are 25 mm thick...coz ma car got 7.5 with spacers and offset like 30 no problem
abcd
PostPosted: Sun Jul 29, 2007 2:51 pm    Post subject: Re: OMG crazy rims Reply with quote
Bro Bimmerasta, Highwaystar & Xsjado
Many thks for your advice
Seems too leceh - better find something with PCD100x4 and centre bore 57 (think shd start looking at rims for new Mini and just add spacer to get flush effect)
Know any shop in JB with good collection of rim for New Mini?
Thks
PostPosted: Mon Jul 30, 2007 5:37 am    Post subject: Re: OMG crazy rims Reply with quote
Thks
Me dunno shop in JB, what is your budget?
abcd
PostPosted: Mon Jul 30, 2007 11:09 am    Post subject: Re: OMG crazy rims Reply with quote
Bro Highwaystar
Max Rm1500?
PostPosted: Tue Jul 31, 2007 6:44 am    Post subject: Re: OMG crazy rims Reply with quote
huhu... get supere30 rims that look like borbet 15". He wanted for 1,600 but guess can nego, specs offset all ngam with E30, just plug and play... give him a call...
WTS E30 Rims by supere30
Page 4 of 4
