Online Now [1877]:
Visitors: 1877
Today: 23030
Total: 30981141
Insulflex® DIY Soundproof to Your Car
Post new topic   Reply to topic   Printer Friendly Page     Forum IndexGeneral Classified
jh6162
PostPosted: Fri Apr 01, 2011 12:33 pm    Post subject: Insulflex® DIY Soundproof to Your Car Reply with quote
DIY Soundproofing to Your Car
Item(s):Insulflex® Heat and SoundProof Material(non adhesive @ no backside glue/gam)
FIRE TEST
www.youtube.com/v/fehC5VAuqv0
Insulflex® Heat and SoundProof Material(non adhesive)
This is HIGH QUALITY product proven with :
Sound & Product Stability
SIRIM BS476 Part 6
SIRIM BS 476 PART 7
SIRIM Certificate (Aug 2010-Aug 2011)
SIRIM (Acoustic Test Report)
Sound Rated at : NRC 0.14
FireTest
Warrington Fire Research Certificate
TUV SUD BS476 Part 6(Fire)
TUV SUD BS476 Part 7(Fire)
SUITABLE for all cars.
Worth your money to buy this HIGH QUALITY product.
Why risk to buy a low quality just to save a few ringgit that has no effect?
Just use a 10mm or 6mm of this HIGH QUALITY
product to get the same result with a minimum space in tight and small area..
Recommended to use on :
1. Doors(Dootrims/Door Panel)
2. Front bonnet
3. Rear trunk lid
4. Boot floor and walls
5. Floor pan
6. Front fender / wheel arch
7. Roof Liner
8. Engine firewall from engine(best result)
Facts:
1 -Great for a quiet and comfortable
2 - Lightweight material
3 - Low water absorption rate(waterproof)
4 - Fireproof
5 - The above average physical properties are values obtained in accordance
with accepted test methods.
6 - At -40°C, Insulflex Closed Cell Insulation becomes hard and as temperature
drops below -40°C will be increasingly brittle; however this hardening
chracteristic does not affect thermal or water vapour permeability.(Waterproof)
7 - The Fire rating standard method of tests conducted under controlled
laboratory conditions is a measure of a material to spread flame when compared
to a known standard and is not intended to reflect hazards presented by this
or any material under actual fire conditions.
Price: RM40 Per Sheet
Standard Sheet Sizes: 3ft x 4ft
Thickness : Available in 6mm & 10mm
Price List for More than one sheet:
10mm
Buy 1 Sheet : RM40
Buy 2 Sheet : RM65
Buy 3 Sheet : RM90
Buy 4 Sheet : RM115
Buy 5 Sheet : RM145
6mm
Buy 1 Sheet : RM30
Buy 2 Sheet : RM50
Buy 3 Sheet : RM70
Buy 4 Sheet : RM90
Buy 5 Sheet : RM110
COD at Taman TTDI Jaya & Shah Alam Area
Postage can be arrange
Note :
*Minimum Order For Postage is 3 Sheet(9ft)
*Postage cost is paid by buyer
*Postage is through Pos Malaysia E-Parcel,will be delivered within 1 week
after payment is confirmed
*Dunlop GP Adhesive/Dunlop CA Adhesive can be used as adheshive as it just rm10-20 per can..combine all cost,it's a cheap DIY..
Malaysia BOLEH!Dont be a lazy bump!
Please CALL
NO SMS
Selangor
Khairul
0179705607
Kuantan
Yo N13 - 0129512320
Post new topic   Reply to topic   Printer Friendly Page     Forum IndexGeneral Classified All times are GMT + 8 Hours
