Online Now [1748]:
Visitors: 1748
Today: 135406
Total: 31093517
M20B20 to M42B18 swap
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sun Feb 20, 2011 4:15 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
puddycat wrote:
kura2 wrote:
puddycat wrote:
can you reason why did you re-tilt your engine angle and cut the engine bracket on the right with the shortening of the manifold ?
Engine bracket cut to cater for 10 degree difference between engine and m20 box. Shortening of the manifold cause mech scare it will hit brake master pump when its running. I don't really agree with their way of doing things though but so far their workmanship looks good enough for me.
okay, since you tilt it back to -10deg, how will you settle the starvation of the cylinder head without oil everytime you start up your engine..there will be non in the hydraulic lifters ? so no lubrication there...
funny these days the mechanics, they can re-event the wheel.....
Not really sure how the mech did it but the oilpan is levelled fine so its not tilted- 10deg.
puddycat
PostPosted: Sun Feb 20, 2011 1:34 pm    Post subject: Re: M20B20 to M42B18 swap Reply with quote
kura2, you still dun get it....
btw, on jpj inspection, cut engine mounting(leg) is not legal...no pass..
PostPosted: Mon Feb 21, 2011 12:40 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
Not sure what you are referring to but the engine is now tilted similar to stock e36. We'll see how it goes with jpj.
PostPosted: Mon Feb 21, 2011 2:59 pm    Post subject: Re: M20B20 to M42B18 swap Reply with quote
how come u need to cut?coz of the gearbox?the mounting from m40 should settle everything and level the engine...
PostPosted: Mon Feb 21, 2011 3:59 pm    Post subject: Re: M20B20 to M42B18 swap Reply with quote
because of m20 g240 box.
PostPosted: Tue Feb 22, 2011 3:31 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
i guess kalau kura2 e30 is m40, this will settle long way back, but its m20 Smile mmmmm
rzonealley
PostPosted: Tue Feb 22, 2011 11:42 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
basicly the conversion is plug n play but since kura2 use back his old m20 gearbox he need to to tilt from my understanding. hehehe
PostPosted: Wed Feb 23, 2011 1:00 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
Korek korek korek guys. Here some updates, hopefully can go puspakom by this week:
Shortened intake manifold
Vanette remote reservoir.
Coil pack will be installed at battery tray. Battery moved to boot.
Wiring in progress.
Jumpman
PostPosted: Wed Feb 23, 2011 2:51 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
Looking good..at least better than mine still stalled at the workshop..lol.
g0dspeed
PostPosted: Wed Feb 23, 2011 5:08 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
sorry kura2 & jumpman... no offense...from my experience... m42 conversion is quite simple....mine was like 2 weeks to settle everything... but.... the mods were neverending... anyhow.. i wish u guys all the best and hope you will enjoy your M42....godspeed!
Jumpman
PostPosted: Wed Feb 23, 2011 6:46 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
bro g0dspeed, I am located in Kuching where there are not many ppl who are expertise in bmw conversions. so far in kch other than mine currently going on, only xsjado has gone the m40-m42 way.
My case is quite different. i bought the engine without the ews module. second issue is with the wiring as the wiring loom was messy when it came (without the x20 connector). so im worried that maybe some wiring are not wired up properly.
so im now trying to resolve the problem between getting the right ecu to bypass ews and proper wiring connection. Need some input tho cos i was told that u can just use a non-ews (pre 94) to bypass the ews system. question is do u also need the non-ews wiring harness?
i have yet to bring to car for diagnostics as i currently have no time.sigh.
PostPosted: Thu Feb 24, 2011 9:41 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
Here's some pics from today. Tested cranking the engine today and its giving out spark and injector are firing too Smile
Battery relocated to boot.
Fresh new harness.
PostPosted: Thu Feb 24, 2011 9:48 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
mine conversion plus a few mods Smile
1. Innovate lc-1 wideband controller.
2. Relocate battery to boot.
3. Megasquirt standalone ecu.
4. New harness for megasquirt.
5. Dual layer nissan servo with remote reservoir.
PostPosted: Thu Feb 24, 2011 10:02 am    Post subject: Re: M20B20 to M42B18 swap Reply with quote
Why don't your mech try to build the harness from scratch? My mech did. For ecu pinout and electrical diagram you can refer to e36 bentley manual. I have the softcopy if you need it. Let me know if you need any bits from the wiring loom as I have plenty lying around.
PostPosted: Thu Feb 24, 2011 3:22 pm    Post subject: Re: M20B20 to M42B18 swap Reply with quote
jumpman please jump on this!!
Page 3 of 7
