Online Now [1859]:
Visitors: 1859
Today: 136113
Total: 31094224
Timing belt changed already...
PostPosted: Sun Sep 05, 2010 4:09 pm    Post subject: Re: Timing belt changed already... Reply with quote
BobTheBuilder wrote:
Timing belt dah tukaq, cooling system pulak problem. Air dok melimpah keluar.
Tadi baru pi Optimum. Tukaq thermostat. Tapi dok tak lama,air melimpah balik. Check punya check, rupanya radiator cap. Tapi tak dan tukaq sebab depa takdak stok. Kedai pun dah nak tutup.
Tunggu isnin nanti la aku pi cari sendiri kat kedai spare part.
Pas tu tadi buat oil change (minyak bawa sendiri), tukaq oil filter, front brake repair kit, thermostat, semua sekali RM410 plus labour.
Raya sakan sungguh E30 aku ni. Lalala...
sama la bro..haha..tukaq termostat sampai 3 kali at last sebab air tsumbat kat dlm blok
PostPosted: Sun Sep 05, 2010 4:13 pm    Post subject: Re: Timing belt changed already... Reply with quote
Bro highwaystar: betoi tu. Tu yang aku tukaq timing belt awai2 tu. Putuih kalu teriak tak berlagu la.
Bro orange: sorry to hear that. At least la ni engine bro dapat valve baru. Smile
haha...xpa...bila dh nk kena overhaul tu baru jumpa bnda yg patut kena buat...piston ring..water jacket..macam2 oil seal..conrod bearing, water,vacuum, oil, petrol hoses...dah jd major overhaul..enjin pun jd macam baru..haha...
PostPosted: Sun Sep 05, 2010 4:24 pm    Post subject: Re: Timing belt changed already... Reply with quote
radiator cap cost dalan rm35 - 45 Wink just changed mine got it at ortojaya sunway mentari for rm 35
BobTheBuilder
PostPosted: Sun Sep 05, 2010 4:26 pm    Post subject: Re: Timing belt changed already... Reply with quote
Bro orange: Blessing in disguise... Dah habih running in ka bro?
BobTheBuilder
PostPosted: Mon Sep 06, 2010 8:37 am    Post subject: Re: Timing belt changed already... Reply with quote
Bro highwaystar: thanks for the info.
Smile My pride and joy: '86 E30 320i(A) 4door Smile
BobTheBuilder
PostPosted: Mon Sep 06, 2010 2:20 pm    Post subject: Re: Timing belt changed already... Reply with quote
Radiator cap dah beli dah. RM35 ja. Kat First Division Jalan Ipoh. Person behind counter was En Kemarudin. Friendly guy. Aku tanya dia aircon E30 ni nak buat kat mana? Dia cakap kat Abang Ramli kat Kg Baru. Ada bro2 yg dah pi kat Abang Ramli ni dak? Tolong share experience. Smile
BobTheBuilder
PostPosted: Mon Sep 06, 2010 2:27 pm    Post subject: Re: Timing belt changed already... Reply with quote
Bro orange: air tersumbat dalam blok, apa penawar dia? Kot-kot la, mana tau... Tapi mintak simpang la...
PostPosted: Mon Sep 06, 2010 6:07 pm    Post subject: Re: Timing belt changed already... Reply with quote
first division been supporting malatbimmer for quite sometime oledi, if you see kem, cakap reinier kirim salam, nick highwaystar dia tak tahu. Cuma kebelakangan nih jarang beli parts kat first division sebab they implement lunch break. So during lunch time tak boleh beli parts Sad
As for aircond, you also can try naidu. Location shell staion next to bangunan kwsp pj, belakang shell station, rege also reasonable. So far so good lah the service, he also good in trouble shooting.
BobTheBuilder
PostPosted: Tue Sep 07, 2010 2:51 pm    Post subject: Re: Timing belt changed already... Reply with quote
Ok bro. If i see brader kem again, i'll tell him you said hi. Thanx for the info on aircon shops.
Aircon dah buat dah. Call Abang Ramli tapi dia dah cuti Raya. So aku pi kat AMB kat jln ipoh. Tukar temp switch yg kat aircon filter. Total cost RM100. Sejuk balik dah aircon aku. Lega rasanya.
Tapi cooling system still kacau la. Kalau drive lama skit, lepas off engine, aku picit radiator hose, cekang abih. Overheat ka macam tu? Temp gauge pulak rosak. Aduhai...
BobTheBuilder
PostPosted: Tue Sep 07, 2010 3:07 pm    Post subject: Re: Timing belt changed already... Reply with quote
Satu lagi nak tanya, radiator fan kat E30 ni boleh buat direct dak? Maksud aku buat bagi dia permanent full blast. Bro2 tolong bagi pendapat skit. Thanx.
PostPosted: Wed Sep 08, 2010 3:30 pm    Post subject: Re: Timing belt changed already... Reply with quote
haha... tak perasan pulak time mekanik tu repair benda ni...tau2 kena charge RM150 including termostat...then temp normal even in trafic jammed
BobTheBuilder
PostPosted: Thu Sep 09, 2010 7:46 am    Post subject: Re: Timing belt changed already... Reply with quote
RM150 kira ok tu bro. Kereta aku la ni tidoq hospital. Alternator kong. Adeh la...
PostPosted: Tue Sep 14, 2010 12:22 am    Post subject: Re: Timing belt changed already... Reply with quote
boleh bro kalo nak buat direct.xde masalah..
bro alternator kong pegi kedai wireman la suruh dia tukar carbon 2 batang tu.
maybe carbon tu dah habis kot.bukak je benda tu xde masalah.
kalau tak silap carbon tu sekali dgn housing dlm RM100++.kalau nak tukar carbon sahaja pun blh jgk.nanti wireman blh solder.
BobTheBuilder
PostPosted: Wed Sep 15, 2010 4:22 pm    Post subject: Re: Timing belt changed already... Reply with quote
Dah try tukaq bro. Tapi tak charging jugak. Test kat Optimum hari tu. Isnin nanti baru depa boleh tukaq alternator sebab adik2 kita kat Optimum tu tak abih cuti raya lagi.
Thanx for the advice bro.
BobTheBuilder
PostPosted: Wed Sep 22, 2010 5:10 pm    Post subject: Re: Timing belt changed already... Reply with quote
Keta dah siap dah Sabtu haritu.
Alternator second hand RM400 plus labour RM50. Dah ok dah. Lega rasanya.
Page 2 of 3
