Online Now [1445]:
Visitors: 1445
Today: 135095
Total: 31093206
m54b30 swap
abcd
PostPosted: Thu Aug 12, 2010 4:51 pm    Post subject: m54b30 swap Reply with quote
hi sifus,
anyone know if it is a straight forward swap to put a M54B30 (wire harness, drivetrain, auto transmission, everything else in engine bay) into a e36 320i ?
and how much will a m54b30 halfcut cost + labor cost to do above?
lastly which JB workshop can be trusted to do a proper job?
TIA
PostPosted: Fri Aug 13, 2010 2:16 am    Post subject: Re: m54b30 swap Reply with quote
I think theres no modification needed in engine bay.Mounting all same.All can fit in nicely.Just pnp.Wire harness maybe some problem coz 36 and 46 are different model and also their engine management system.Halfcut last time heard around 7k above.Sorry dont know which w/shop in jb are capable.
abcd
PostPosted: Fri Aug 13, 2010 5:32 am    Post subject: Re: m54b30 swap Reply with quote
Hi bro,
If i take the whole engine bay from a e46 330i/ci halfcut, it will be 100% PNP?
Shuld I use the gbox, drive shalf, auto tranmission, exhaust system from the e46 330 as well and r they also PNP?
many thks
stea2221
PostPosted: Fri Aug 13, 2010 9:26 pm    Post subject: Re: m54b30 swap Reply with quote
I dun think u wud get m54b30 half cut for 7k, more like 18k
PostPosted: Sat Aug 14, 2010 8:46 pm    Post subject: Re: m54b30 swap Reply with quote
bro better take cap singa e46 about 20k++ can get already.. Twisted Evil
PostPosted: Sun Aug 15, 2010 12:23 am    Post subject: Re: m54b30 swap Reply with quote
Eh alamak sorry 4 the price dude.Its over then 7k as i know.The engine will fit in nicely to 36.the gearbox is ok but the propellar need to check if u wanna use previous diff.46ci diff mounting maybe a lil bit defferent with current.the exhaust flow also need some modification coz 46ci route at underbody are not same with 36.find a professional mech to swap in ur dreaming or later u will get sick to countermeasure others problem coming.
e30_Addict
PostPosted: Tue Oct 05, 2010 6:50 am    Post subject: Re: m54b30 swap Reply with quote
abcd wrote:
hi sifus,
TIA
Anything is possible and it has been done b4. But it is not a pnp job. Specially the wiring. e36 runs on obd 1/obd 2 with or without ews (depending on the m50/m52 engine) and m54 run on obd2/3 with ews2. So you need to by pass the ews or know how to map the wires.
This is just one thing, then the mechanicals.
Why not find a s50/s52 and swap that into your e36?
(pic is s54 into an e30)
PostPosted: Tue Oct 05, 2010 9:36 am    Post subject: Re: m54b30 swap Reply with quote
anything can be done...but do we have the expertise here? or is there any mech who wants to do it? thats the thing..
PostPosted: Wed Oct 06, 2010 5:11 am    Post subject: Re: m54b30 swap Reply with quote
just the wiring issue makes a big problemo from obd1~obd2.
ews?? Run for your lifeeeee!!!! Confused
sach767
PostPosted: Thu Oct 07, 2010 6:45 am    Post subject: Re: m54b30 swap Reply with quote
spot on actually...
also the cost to do it and parts availability? way way way more affordable in the UK or US ... even engines are aplenty for you to choose from...
btw, M52B28 already cost around MYR7K here... Surprised
sorry bmw, but if you want more ummppph the reliable way... the e36 will be mad on a 2JZ Razz (bolehland mechanic/workshop also very pro wt this set up)
if you still want a german under the hood, another no sakit kepala solution will be to shove a 3.0 stroker kit to ur existing 6 cylinder engine... wt some fat ass m3 cams .. can asap the m54b30.. hehehe
good luck..
By v_sach at 2008-08-20
PostPosted: Fri Oct 08, 2010 9:40 am    Post subject: Re: m54b30 swap Reply with quote
stroker with e46ci 330 block.hehehe... gerenti mcm pelesit kota.
