Online Now [2314]:
Visitors: 2314
Today: 35482
Total: 30495298
temp rising
PostPosted: Sat May 15, 2010 4:23 am    Post subject: temp rising Reply with quote
theis has always happened to my car e30 m40-m42,even when i changed engine, everytime i turn on the air cond,temp rises,maybe its the dodgy little electric fan for the aircond,its got white blades,are the other m40 fans white?
PostPosted: Sat May 15, 2010 4:32 am    Post subject: Re: temp rising Reply with quote
My small electric fan is black. Most likely some other part of your cooling system is not working properly or has a leak/etc.
PostPosted: Sat May 15, 2010 11:50 am    Post subject: Re: temp rising Reply with quote
no leaks,fan clutch ok,newskool blades(not them noisy ones)only problem is when i turn on the aircond,but then its a good way to get my temp up,otherwise takes ages to warm up...
PostPosted: Sat May 15, 2010 1:13 pm    Post subject: Re: temp rising Reply with quote
How old's the radiator?
What kinda coolant mixture are you using?
Thermostat is the correct temperature spec?
Smile
PostPosted: Sun May 16, 2010 2:48 am    Post subject: Re: temp rising Reply with quote
radiator is as old as the car..1991,bme coolant,thermostat??duno,even with the old engine with a new thermo didn't help...
PostPosted: Sun May 16, 2010 5:22 am    Post subject: Re: temp rising Reply with quote
Well just some ideas:
- Radiator is old, maybe the fins are clogged or certain flowpaths are broken (by stones etc) so the efficiency is not as good already.
- Thermostat might be the wrong spec, i.e. the temperature at which it opens and lets coolant flow through, if it's too high, then it opens too late and the engine can't cool down enough. But I doubt this tho since M40 already uses one of the higher temp ones - 88C
PostPosted: Sun May 16, 2010 6:38 am    Post subject: Re: temp rising Reply with quote
same thing with my old daihatsu rocky,aircond on= temp up!thnx for the ideas!!
puddycat
PostPosted: Sun May 16, 2010 5:08 pm    Post subject: Re: temp rising Reply with quote
for a age of the radiator of 91, it should have been made into a front end of the new 5... re-cycled...hehehe
it's the radiator... borrow a good used one and try it for a few days.. see what's wrong...by the way, is the radiator the overflow tank together or the M20, pre-Ljet or the motronic type ?
PostPosted: Mon May 17, 2010 1:05 pm    Post subject: Re: temp rising Reply with quote
yep together,will try to source another radiator...thnx!
PostPosted: Mon May 17, 2010 4:52 pm    Post subject: Re: temp rising Reply with quote
okay dunno might help or not
your aircond on baru temp naik, logically speaking if u using electric fan, when aircond on, the electric fan running at the same speed, whereas it should runs quicker, the engine idling oso faster since the ecu detects tension driven by compressor belt therefore engine temp naik but cool air by fan is lower.
Kalau air radiator cepat habis, radiator is working kalau tak bocor, if not it got to do with waterpump or thermostat and maybe your electric fan switch.
Ntah betul tak pun tak tahu, try luck lah nih
teknokrat
PostPosted: Tue May 18, 2010 3:30 am    Post subject: Re: temp rising Reply with quote
Nak tanya satu soalan sebab aku x brp paham sgt sistem BMW ni mcm mna.
E30 aku bila start je enjin fan trus jalan. Is it normal or the fan is wired direct?
