Online Now [1362]:
Visitors: 1361
Today: 141550
Total: 31099661
my e36 alarm signal menyala je.HELP!
alipe36
PostPosted: Wed Apr 21, 2010 1:20 pm    Post subject: my e36 alarm signal menyala je.HELP! Reply with quote
nak tanya sifuuu.alarm signal aku ada masalah.BREAK LIGHT CIRCUT!!!!!. mula2 signal check bekelip2 pastu menyala je.aku dah tukar sensor abs break pad dah.tapi nyala gak.ari tu time ake cuci keta aku,air penuh dalam break light aku.aku cabut socket and bukak la nak service.pas kejadian tu naik alarm.adakah pasal aku pasang alarm?sebab keta aku bru wat alarm
View user's profile Send e-mail Photo Gallery
PostPosted: Wed Apr 21, 2010 4:07 pm    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
ini mesti pasal wiring, okey pasal check light tu camne masih menyala ker?
check light menyala either kereta tak service or tak reset.
alarm pulak wiring pakai original atau tarik mana2?
solution, pi cari wireman
PostPosted: Wed Apr 21, 2010 11:33 pm    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
Wiring is a very sensitive issue dude.please check your wiring 1st.
Jgn jump mana² wire.that is very² important.tanya kedai tu dia tarik wire dpd mana.
sach767
PostPosted: Thu Apr 22, 2010 2:45 am    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
Try Change your brake switch, located under steering, inside dashboard. Under RM100/=
common problem wt e36,
good luck
By v_sach at 2008-08-20
alipe36
PostPosted: Thu Apr 22, 2010 4:05 am    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
aku dah hantar kdai.after aku change break pad and sensor abs.foremen dah reset dah.aku rasa aku dah dapat tangkap mana problemnya.aku pasang alarm kat kdai aksesori.cina tu ada jumper kat wayer brek for centrl lock.sifu rasa mcm mana.help
alipe36
PostPosted: Thu Apr 29, 2010 10:15 am    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
THANKZ sach767.....the problem was settle..i buy the break switch about rm75 only and pasang sendiri.thanz a lot
sach767
PostPosted: Fri Apr 30, 2010 4:16 am    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
no problems... go enjoy ur ride now!! no need to brek... hahaha
PostPosted: Fri Apr 30, 2010 6:37 am    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
terrer lah sach... good one!
sach767
PostPosted: Fri Apr 30, 2010 2:38 pm    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
dah 6 tahun kena goreng dengan e36 nie.. cukup masak!! pocket lagi masak... Wink
PostPosted: Fri Apr 30, 2010 11:47 pm    Post subject: Re: my e36 alarm signal menyala je.HELP! Reply with quote
6 tahun? Waaa.... dah boleh dipanggil otai ni Smile
