Online Now [2629]:
Visitors: 2629
Today: 171802
Total: 31116477
Introducing my new shoes
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Apr 24, 2010 8:14 am    Post subject: Re: Introducing my new shoes Reply with quote
bro reinier, please dun give a fark what other pplz may or may not comment....
its everyones own taste Very Happy
i support u man, as long u are happy... :))
BTW, AWESOME FARKING AWESOME!!!!!!!!! will make the car look so fucking gorgeous....
malatbimmer kaki boleh masuk performance bmw sekali lagi!! :))
PostPosted: Sat Apr 24, 2010 8:30 am    Post subject: Re: Introducing my new shoes Reply with quote
bro, that is quite freaky...
Yah i know... hehehehe and i wont sell my rims hahahaha.... i 'potong' stim you guys ahh... just want to share with u guys and being transparent. I had this setup before.. no harm done Smile
It has to be sealed the old hole first, then re-drill, this way the metal structure will be intact Smile
Thanks tombstone, been there done that and quite like it hehehehehe
PostPosted: Sat Apr 24, 2010 10:53 am    Post subject: Re: Introducing my new shoes Reply with quote
sealed the old hole first?? Wah boleh bikin ka ini macam?
No effects? Are u sure? Whos done dis before?
creezchan
PostPosted: Sat Apr 24, 2010 11:38 am    Post subject: Re: Introducing my new shoes Reply with quote
fulamak i got to see this personally
PostPosted: Sat Apr 24, 2010 2:40 pm    Post subject: Re: Introducing my new shoes Reply with quote
me, me ,me Smile sure got effects, rim slightly heavier Smile
like i said, i've been using this setup before... Smile my first BBS was from E34, use it for 3 years and sold for RS.. the owner until today masih pakai itu rim...
Okay, you sure noticed japanese rim setup sometime got 8 hole, 9 hole and 10 hole... that one also itu lubang semua exposed takde seal... the process of making the lugs oso from drilling.... so, germany aloy i think as good as japan aloy.. taiwan dunno lorrr...
i did not ask you guys to do the same, this is my way of satisfying myself to the max kekekke, if you have a doubt don't do it.... oh maybe you can just wait till i use it lahh... kekekeke
PostPosted: Sat Apr 24, 2010 2:41 pm    Post subject: Re: Introducing my new shoes Reply with quote
yes you can bro, wait till i mount on ma ride Smile
kombat_kanan
PostPosted: Sat Apr 24, 2010 4:00 pm    Post subject: Re: Introducing my new shoes Reply with quote
bro highwaystar; sorry it was not very clear to me on this re-drilling works:
appreciate if you could enlighten me abit bro Smile
refer your pic that I amended; my questions:
1. RED - 5 lugs: were those the original holes?
2. BLUE - 4 lugs: are those the ones you redrilled?
3. GREEN: what are those? were those the original 5-lug holes? did you plug, fill, and weld shut the original holes? - if yes, how did you do this?
apology if too many questions bro. but thats just plain interesting! Rolling Eyes
PostPosted: Sat Apr 24, 2010 6:31 pm    Post subject: Re: Introducing my new shoes Reply with quote
Okay bro, i try to explain some since i pass to machine shop to do.. so i just know bit of the process.
These were substitute holes, some rim they had 5 lugs hole for 120pcd and 114pcd. if these rim were made for 120pcd, the 114pcd will be slightly smaller without the bolts bevels. These were made as a guide if you wish to drill 114pcd.
Some of bbs wheels (see the reverse side picture) come in FLAT base and some got grooves or longkang. ONLY flat base can be drill and if longkang cannot, because the drilled part with longkang will not sit perfectly on your knuckle.
Yes this is the new PCD with 100pcd setting, you noticed the center cone also has been fitted
These are the original 120pcd 5 lugs hole, it has been heated plug, the machine shop measure perfectly, heat the metal and plug it in. And i don't exactly know how they do this maybe using hydraulic pump.
In order to remove this metal piece, you CAN'T simply knock with hammer, it has to drill out on which the plug cant be reuse. they need to create a new plug. These process can be done once... twice tak boleh:)
hope these will answer your question. cheers:)
kombat_kanan
PostPosted: Sat Apr 24, 2010 6:39 pm    Post subject: Re: Introducing my new shoes Reply with quote
thank you very much bro highwaystar. now i'm quite well informed on the nature of this process.
one of these days if i plan to do this, will pm you for further info.
cheers Smile
PostPosted: Sat Apr 24, 2010 6:42 pm    Post subject: Re: Introducing my new shoes Reply with quote
cheers Smile
jangan curi tayar aku ya Smile
kombat_kanan
PostPosted: Sat Apr 24, 2010 6:46 pm    Post subject: Re: Introducing my new shoes Reply with quote
cheers Smile
i'd consider beg or borrow but not steal bro. dont worry haha..
PostPosted: Sat Apr 24, 2010 9:09 pm    Post subject: Re: Introducing my new shoes Reply with quote
Bro. Highway.... Freaking Awesome Piece Of Work You Have Their Man....
I envy You & Your BBS......
But i have a few question of my own if you don't mind me asking....
1. What is Electro Plating All about...?
2. I have found 2 sets of BBS RS....
It's 16 Inch x 7J front, 8J rear....
It's 4 lugs... but the problem is it's 114.3 PCD in size....
Can it be use on a e30....?
PostPosted: Sat Apr 24, 2010 11:57 pm    Post subject: Re: Introducing my new shoes Reply with quote
Yayy.. Ok now i understand Smile
PostPosted: Sun Apr 25, 2010 8:09 am    Post subject: Re: Introducing my new shoes Reply with quote
1. Electro Plating is a process to chrome plating, gold plating, bronze etc.
2. You need to know what offset... e30 offset OR ET should be 25 to 16.
114.3 can be drill across and make 8 hole, 1 original 114.3 and the other 100pcd. However you also need to mod center bore or center cone to 57.1. This drill should be made only flat base surface (reverse side of the rim) if got groove, i cant be drill.
Cheers
PostPosted: Sun Apr 25, 2010 8:18 am    Post subject: Re: Introducing my new shoes Reply with quote
Okay man, glad i can help.
A FRIENDLY NOTES
I DO NOT HELD ANY RESPONSIBLE IF ANYTHING HAPPENED TO YOU OR YOUR RIDE, THIS METHOD OF MODS ALSO WILL MADE YOUR RIM LESS VALUE SINCE IT WAS CONSIDERED 'TEMPERED'.
I DID THIS BECAUSE I DO NOT INTEND TO SELL MY RIM. THANK YOU[/B]
HAPPY MODS!
Page 3 of 6
