Online Now [767]:
Visitors: 766
Today: 102373
Total: 31060484
Alternative external fuel pump for M20 l-jet
PostPosted: Mon May 10, 2010 3:04 am    Post subject: Alternative external fuel pump for M20 l-jet Reply with quote
My pump died after 25 years of service Sad I am looking for alternative fuel pump. Will it be possible to use performance aftermarket pump? Or can i use pump from other make e.g. proton/merc? Sharing is caring hehehe
PostPosted: Mon May 10, 2010 5:22 am    Post subject: Re: Alternative external fuel pump for M20 l-jet Reply with quote
use peformance aftermarket or stick to ori...
PostPosted: Mon May 10, 2010 8:00 am    Post subject: Re: Alternative external fuel pump for M20 l-jet Reply with quote
for aftermarket, do i need to use adjustable fpr to maintain 3 bar pressure or stock fpr will do?
PostPosted: Mon May 10, 2010 10:36 am    Post subject: Re: Alternative external fuel pump for M20 l-jet Reply with quote
i am using Walbro 255lph internal fuel pump, just abit of modification and i dont need to use adjustable fpr
puddycat
PostPosted: Mon May 10, 2010 2:31 pm    Post subject: Re: Alternative external fuel pump for M20 l-jet Reply with quote
kura... why use a high fuel pump when the fpr still restricts the amount of fuel using.. some more why use a high pressure pump when the common ones is up to 6bar.. nough to power the 2.0L L-jet.. the L jet fpr is up to 2.0 to 2.5bar.. if u use the high one, be prepare for the injectors to leak under high pressure...
just go get a new pump or use second hand pump..
oh, high pressure fuel pumps are mostly recomended for turbo/sc engines due to the need for fuel and constant pressure in the lines..
if you put for a NA car, waste of time cos the pressure is limited to the duty cycle of the injectors..
cheers..
PostPosted: Mon May 10, 2010 4:16 pm    Post subject: Re: Alternative external fuel pump for M20 l-jet Reply with quote
good one puddycat:)
PostPosted: Tue May 11, 2010 9:36 am    Post subject: Re: Alternative external fuel pump for M20 l-jet Reply with quote
cheers..
thanks bro, question answered Smile
