Online Now [1739]:
Visitors: 1739
Today: 11645
Total: 31140827
Odometer not function.
teknokrat
PostPosted: Thu Apr 08, 2010 1:38 pm    Post subject: Re: Odometer not function. Reply with quote
evilnickwong wrote:
If I'm not wrong, that means you are using a late model fuel gauge on an early model car. Could be your meter is not original or the fuel gauge was swapped at some point with the wrong type.
mine is 1984 model..meter is original. Very Happy
PostPosted: Fri Apr 09, 2010 3:43 am    Post subject: Re: Odometer not function. Reply with quote
Tak silap aku meter e30 ada 2jenis.. Auto Meter & VDO. Correct me if i'm wrong...
BlackE34
PostPosted: Fri Apr 09, 2010 8:34 am    Post subject: Re: Odometer not function. Reply with quote
i had the same prob too... lama2 meter minyak ngan temp je jalan ... tukar satu set bro ..
Started off with a Bimmer.... Ending Life with a Bimmer
PostPosted: Mon Apr 19, 2010 11:41 pm    Post subject: Re: Odometer not function. Reply with quote
Yes.Its VDO & Motormeter...
AERO
PostPosted: Tue Apr 20, 2010 4:38 am    Post subject: Re: Odometer not function. Reply with quote
just to check, my fuel low light does not light up, have check the buld it is not fuse..... any suggestion.
PostPosted: Tue Apr 20, 2010 6:26 am    Post subject: Re: Odometer not function. Reply with quote
bulb doesn't blow are they connected properly?, swap bulb
PostPosted: Wed May 19, 2010 1:30 pm    Post subject: Re: Odometer not function. Reply with quote
Bro...mana ada jual meter punya bulb. Wa punya meter dah malap mcm lampu tido daa..huhu... Then tgh cari gak bulb for lampu kat atas bumbung & bulb no plet belakang....help..help..
PostPosted: Wed May 19, 2010 2:55 pm    Post subject: Re: Odometer not function. Reply with quote
selalunya kedai electronic ada jual kalau takde kat sparepart shop pun ade
PostPosted: Wed May 19, 2010 5:30 pm    Post subject: Re: Odometer not function. Reply with quote
Danke highway! Nanti aku try ushar..
