Online Now [1332]:
Visitors: 1331
Today: 141444
Total: 31099555
e36 328 long shaft
bigjoe74
PostPosted: Sat Sep 30, 2006 2:43 pm    Post subject: e36 328 long shaft Reply with quote
looking for e36 328 longshaft..pm me..
E36 outside RB20 inside
PostPosted: Sat Sep 30, 2006 10:32 pm    Post subject: Re: e36 328 long shaft Reply with quote
adimas apasal gan kau punye long shaft, ada woble ker pegi hantar for balance dulu, if the thing betul2 rosak baru ler carik lain bro..
PostPosted: Sun Oct 01, 2006 5:42 am    Post subject: Re: e36 328 long shaft Reply with quote
center bearing dah check?
bigjoe74
PostPosted: Fri Oct 06, 2006 10:44 am    Post subject: Re: e36 328 long shaft Reply with quote
all check already...sebenar nye bukan aku punya kereta..kawan aku punya lah...140km dia start gegar...suspect dia punye longshaft..jadi aku nak cari longshaft e36 328 4 speed...terima kasih...hehehe
PostPosted: Mon Oct 09, 2006 2:21 am    Post subject: Re: e36 328 long shaft Reply with quote
woh... okey malatbimmer will look for you.
possibility:
Lower Arm and Upper Arm (either bushing or the whole system)
Centre Bearing
Coupling
Disc Rotor Front
LongShaft.
For me, long shaft memang jarang rosak, unless ter accident or factory defects. This happened to my E34. Bila reached 120 - 150 start gegar or sound macam Speaker bass.... Scheme brake rotor - sama jugak, then tukar long shaft, pun sama jugak (lucky can return back). In the end, tukar Brand New set of Lower arm with bush, Centre bearing and coupling... HAPPY TILL NOW!
kekadang centre bearing tuh nampak jer okay, tapi bearing dalam die mungkin dah karat, atau cracks. Mine cracks dan haus.
If the above semua you dah tukar, then long shaft it is. Laughing
