Online Now [1229]:
Visitors: 1229
Today: 142755
Total: 31100866
Oil cooler
PostPosted: Mon Feb 23, 2009 11:51 am    Post subject: Oil cooler Reply with quote
I want to install an oil cooler using universal oil cooler kit.
the benefit is i can get low temp for my engine oil.and got no prob for long distance.
the question is.. can i use it? didnt see any bm's use that before.afraid if its only for japs car.
PostPosted: Tue Feb 24, 2009 1:57 am    Post subject: Re: Oil cooler Reply with quote
mmmm yes, tak pernah nampak pun. i guess it is best to use bmw oil cooler.
mine will install soon heheheh... came with half cut.
PostPosted: Tue Feb 24, 2009 2:28 am    Post subject: Re: Oil cooler Reply with quote
powerderful
PostPosted: Tue Feb 24, 2009 6:11 am    Post subject: Re: Oil cooler Reply with quote
if u want oil cooler, better to get the full set from halcut. Cause it has the proper piping. Last time i bought the oil cooler without the piping, end up returning it back.
PostPosted: Tue Feb 24, 2009 6:10 pm    Post subject: Re: Oil cooler Reply with quote
m20b25 ada oil cooler.. can't fit to m40 engine rase.. my car m20b20 installed oil cooler get from half cut.. if complete set.. PnP Smile
PostPosted: Wed Feb 25, 2009 1:54 am    Post subject: Re: Oil cooler Reply with quote
funny...i tot oil cooler is meant for racing purpose as the engine is operating under consistant high rpm which churns out a lot of heat.
for street driving, oil cooler would not be required? juz a thought....
PostPosted: Wed Feb 25, 2009 2:00 am    Post subject: Re: Oil cooler Reply with quote
its just a precaution , in case the engine encounters situation where it needs better oil cooling Smile
PostPosted: Wed Feb 25, 2009 2:41 am    Post subject: Re: Oil cooler Reply with quote
yes, wks said is true... the oil also extra 1 litre kot.. this is to fill up the oil cooler also. mmm yummy!
PostPosted: Fri Feb 27, 2009 6:26 am    Post subject: Re: Oil cooler Reply with quote
So if this is the answer then tak lama lagi i mau belila... Hehehehe....
halfcut pun halfcutla.... Smile
qu88
PostPosted: Fri Mar 26, 2010 6:11 pm    Post subject: Re: Oil cooler Reply with quote
how much d oil cooler??
bob_sempol
PostPosted: Sat Mar 27, 2010 1:48 am    Post subject: Re: Oil cooler Reply with quote
aku punya m20b25 ada oil cooler.. kalu org x tau depa kata 2 intercoler turbo hehehe Laughing Laughing Laughing
PostPosted: Sun Mar 28, 2010 12:41 am    Post subject: Re: Oil cooler Reply with quote
How much bro? Bumper chasis nk kena modified x bcoz aku tgk mcm xde ruang je nk letak oil cooler kt keta aku... How to install to m20b20 yg mmg xde oil cooler? Rolling Eyes
PostPosted: Sun Mar 28, 2010 4:05 pm    Post subject: Re: Oil cooler Reply with quote
mmg PnP no modified.. but like chris said.. must get complete set.. coz dlm RM500 rase.. maybe less.. tgk berapa dpt la.. Smile
PostPosted: Mon Mar 29, 2010 2:05 am    Post subject: Re: Oil cooler Reply with quote
Normally diaorg mount dkt support radiator bawah tu.
kalo piping ori dia panjang sikit so bolehla mount kat situ.So kalo pakai bumper m-tech tu dua lubang angin yg panjang tu adalah utk angin masuk ke oil cooler..
genozide
PostPosted: Tue Apr 06, 2010 7:40 am    Post subject: Re: Oil cooler Reply with quote
Oil cooler is standard for M20B25 engines fitted into E30
