Online Now [1335]:
Visitors: 1335
Today: 134983
Total: 31093094
E39 528i - Cracked Cylinder Head
sach767
PostPosted: Fri Feb 26, 2010 5:00 am    Post subject: E39 528i - Cracked Cylinder Head Reply with quote
Hi Guys..
Im looking for the below .. any leads wt reasonable price?
E39 528i YR2000 Double Vanos
Thanks
sach
By v_sach at 2008-08-20
mafia
PostPosted: Fri Feb 26, 2010 6:46 am    Post subject: Re: E39 528i - Cracked Cylinder Head Reply with quote
how did it crack bro?... i tot i saw in mudah... check it out or call pussy
sach767
PostPosted: Sat Feb 27, 2010 4:36 am    Post subject: Re: E39 528i - Cracked Cylinder Head Reply with quote
hi mafia, hows family life? busy i guess, seldom see u online..
actually my cousin just got the car about 2 months back. had overheating issue's, changed the whole cooling system and all but problem surfaced again after a couple of weeks wt additional vibration on cold starts. while looking at other possibilities and changing plugs.. ada water in one of the cylinders. so decided to go for top overhaul. open her up, and the crack surfaced, Sad hard luck i guess .. anyway the dealer has agreed to pay the cost ...
the one in mudah for Single vanos ler.. anyway found some, just a matter of best price now...
thanks for the heads up...
puddycat
PostPosted: Tue Mar 02, 2010 1:40 pm    Post subject: Re: E39 528i - Cracked Cylinder Head Reply with quote
double vanos heads are very expansive..they range from 3.4k to 6k even !!
sach767
PostPosted: Tue Mar 02, 2010 2:15 pm    Post subject: Re: E39 528i - Cracked Cylinder Head Reply with quote
got it 3.8K .... thank you
sach767
PostPosted: Wed Mar 03, 2010 7:01 am    Post subject: Re: E39 528i - Cracked Cylinder Head Reply with quote
As some of you know, Ive been looking for a replacement and found one!
Its a528i Double Vanos cylinder head.. if you see the pic below, just above the 5th cylinder theres a no engraved 1/3 on my ori part, but on the replacement part it says 1/2..
what is this indicating, does it make any diff? your urgent help is much appreciated...
thank you guys..
