Online Now [2410]:
Visitors: 2410
Today: 168944
Total: 31115048
fuel pump not functioning
PostPosted: Thu Jan 21, 2010 4:40 am    Post subject: Re: fuel pump not functioning Reply with quote
cuba tengok oil filter kt bawah botol minyak power steering tu.kalo fuel pump ok,filter minyak adalah masalahnya ko try buat direct je minyak tu x payah masuk ke filter lagi.
PostPosted: Thu Jan 21, 2010 11:01 am    Post subject: Re: fuel pump not functioning Reply with quote
ok bro mtech...nnt saya try check
PostPosted: Thu Jan 21, 2010 11:20 am    Post subject: Re: fuel pump not functioning Reply with quote
tukar engine jer terus kekekekkekeke
bob_sempol
PostPosted: Thu Jan 21, 2010 12:31 pm    Post subject: Re: fuel pump not functioning Reply with quote
ya betullll aku setuju tukar jer mintak kat shul engin 2.7 dia.hehehe
PostPosted: Thu Jan 21, 2010 12:55 pm    Post subject: Re: fuel pump not functioning Reply with quote
hahahaha...kalau ada enjin free aku mau....
PostPosted: Thu Jan 21, 2010 3:11 pm    Post subject: Re: fuel pump not functioning Reply with quote
orangebmw wrote:
checked..fuel pump relay ok....hahaha...apa lagi selain relay fuel pump?
tell me how you check your fuel pump relay.... did you swap relay?
PostPosted: Thu Jan 21, 2010 3:15 pm    Post subject: Re: fuel pump not functioning Reply with quote
tapi dia kata, bile test fuel pump ok, tapi masa install tak ok... camne nih, disconnect your fuel hose, try on ignition, kalau minyak terpancut fuel pum okay, check spark plug ada letrik tak, check botol susu (distributor coil). mmm i'm sure this nothing to do with fuel filter, fuel filter kalo problem enjin semput...mmmm
PostPosted: Thu Jan 21, 2010 11:34 pm    Post subject: Re: fuel pump not functioning Reply with quote
yes.. yes.. yes.. sorry²...
tula rasanya ada something yg problem dekat wiring ni.
try mcm bro highway kata,kalo minyak pancut masa pasang then means fuel pump okla tu.
kot² seblm jd problem ni ada tangan gatal ke usik apa² or install apa² dan main wiring.takut ada effect pulak.anything please update orange
PostPosted: Fri Jan 22, 2010 12:07 am    Post subject: Re: fuel pump not functioning Reply with quote
hahaha, baru saya teringat.
Dah dapat problem you, please clean or check your Control Unit Module, benda macam kuih semprit yang lekat di firewall yang bahagian belakang fuse box, buka kasi bersih dgn wd40 lepas tuh try start, kalau best, tukar 2nd hand punya. Good luck, memang case electronic.
PostPosted: Fri Jan 22, 2010 7:13 am    Post subject: Re: fuel pump not functioning Reply with quote
mantap bro.maybe can solve...
but theres always an electrical problem cause by this kuih semprit.
kenapa ek?
PostPosted: Fri Jan 22, 2010 8:31 am    Post subject: Re: fuel pump not functioning Reply with quote
kenapa ek?
ntah, might due to aging (dah tua) heheheh, please give feedback orangebmw Laughing
PostPosted: Sat Jan 23, 2010 2:23 am    Post subject: Re: fuel pump not functioning Reply with quote
injector driver?
faliq3201
PostPosted: Sat Jan 23, 2010 4:08 am    Post subject: Re: fuel pump not functioning Reply with quote
Twisted Evil fuel pump mulfunction - condition
Confused due to kueh semprit short curcuit(aging)dah tua -course
Wink change kueh semprit to rectify-remedy
orangebmw how?solve or not? Rolling Eyes
PostPosted: Sat Jan 23, 2010 5:31 pm    Post subject: Re: fuel pump not functioning Reply with quote
Aku dah kena problem Control Unit nih,lebur rm280 beli baru jenis HuGO made in Germany. Yg Bosch murah sket tapi xdak stok plak... Kalu bleh dpt 2nd hand kedai potong mmg nasib baik la,kt penang benda2 camnih mmg susah mau carik. So keta hang apa crita oren??
PostPosted: Sun Jan 24, 2010 5:25 am    Post subject: Re: fuel pump not functioning Reply with quote
btw,ive been told by some 'otai' out there its called a hybrid.
its an additional electrical part for distribut the electric flow to others.
Page 2 of 3
