Online Now [1780]:
Visitors: 1780
Today: 92999
Total: 31051110
(Need Help) Hartge 16" with offset +45
lempeng7
PostPosted: Tue Dec 15, 2009 1:49 am    Post subject: (Need Help) Hartge 16" with offset +45 Reply with quote
Hi all,
I found a Hartge rim 16" inch but with offset +45. Its 4 lugs.
I just shocked and wondering if it could be direct fit to my E30.
As I know, offset range for E30 is around 15~30.
I thought that all Hartge rim can be fix to E30.
BTW, the width of the rim would be either 6.5 or 7.
Tyre size is 195/50/16
Any idea or advise?
PostPosted: Tue Dec 15, 2009 2:26 am    Post subject: Re: (Need Help) Hartge 16" with offset +45 Reply with quote
offset E30 is 16-26. if the hartge +45, might be for cooper. forget it, nanti nyesal. mine use 16 bbs, rim width 7 offset 26. tyre setup 205/50/16.
hartge cooper lugs 4x100
PostPosted: Tue Dec 15, 2009 5:06 am    Post subject: Re: (Need Help) Hartge 16" with offset +45 Reply with quote
ive seen hartge 16s on a ke70 station wagon in kuching ,must be offset more than 35 by the looks....get spacers...
PostPosted: Wed Dec 16, 2009 4:17 am    Post subject: Re: (Need Help) Hartge 16" with offset +45 Reply with quote
Aiyoo... Hartge 16" ka... sure superb bro! 4 lug plak tu...komfem rim for mini cooper.. get spacer la bro!
PostPosted: Wed Dec 16, 2009 7:36 am    Post subject: Re: (Need Help) Hartge 16" with offset +45 Reply with quote
spacers are kinda a bad idea....... get a rim with the correct offset instead.
lempeng7
PostPosted: Sat Dec 19, 2009 6:37 am    Post subject: Re: (Need Help) Hartge 16" with offset +45 Reply with quote
Thank you all for the advise...
I've cancel to buy the Hartge rim.
So BTW, any 16" E30 rim for sale?
Planning to downgrade from 17" to 16. Or anyone planning to use 17" rim then can swap with me.
Thanks......
PostPosted: Sat Dec 19, 2009 2:46 pm    Post subject: Re: (Need Help) Hartge 16" with offset +45 Reply with quote
im using hartge rims with et45
custom made spacers..no problem whatsoever
make sure it is a hub eccentric spacers
