Online Now [2090]:
Visitors: 2090
Today: 115253
Total: 31073364
fuel pump not functioning
PostPosted: Wed Jan 20, 2010 10:03 am    Post subject: fuel pump not functioning Reply with quote
last few days..lepas isi minyak..start enjin x hidup...malu ja start x hidup lepas isi minyak Very Happy ...pomen kata fuel pump kong...tp check fuel pump kat luar...fuel pump ok..check relay...relay pun ok...check fuse...fuse pun ok...skarang tengah pening pikir apa masalah...ada sapa2 boleh tolong x?
PostPosted: Wed Jan 20, 2010 10:05 am    Post subject: Re: fuel pump not functioning Reply with quote
current kat spark-plug masuk tak? kete apa nih E30 Motronic? L-jet M50 E34?
PostPosted: Wed Jan 20, 2010 10:27 am    Post subject: Re: fuel pump not functioning Reply with quote
Crank sensor? Battery kiok? Got current onot?
PostPosted: Wed Jan 20, 2010 11:56 am    Post subject: Re: fuel pump not functioning Reply with quote
L-jet M20B23...betri semua ok...cranking tp x hidup jugak...bila fuel pump buka test kat luar ok..tp bila pasang balik kat keta fuel pump x jalan...
PostPosted: Wed Jan 20, 2010 1:22 pm    Post subject: Re: fuel pump not functioning Reply with quote
one question. minyak ko kering ker masa isi balik tu? ko cuba pancing petrol kat throttle body ko, slalunya bila minyak kering mmg susah nak idupkan balik tp dia akan hidup jugak after a few try...pastikan minyak penuh btol2...lagi satu cuba check kat plug wires ko mana tau ader leak ker...ko start keta lps suh sorang duk usha kat engine mana la tau ader api bocor ke hehehehhee
PostPosted: Wed Jan 20, 2010 3:33 pm    Post subject: Re: fuel pump not functioning Reply with quote
dah check semua bro...ni yg tgh musykil ni...
PostPosted: Wed Jan 20, 2010 4:07 pm    Post subject: Re: fuel pump not functioning Reply with quote
ahhhh, nasuk balik tak hidup? Fuel pump relay
faliq3201
PostPosted: Wed Jan 20, 2010 4:27 pm    Post subject: Re: fuel pump not functioning Reply with quote
fuel pump failure kot...maybe need to replace the fuel pump assy...correct me if i'm wrong...
PostPosted: Wed Jan 20, 2010 5:41 pm    Post subject: Re: fuel pump not functioning Reply with quote
if fuel pump failure how come you check boleh pulak, then when you install tak boleh???
Do you know which and where is the fuel pump relay tak?
PostPosted: Wed Jan 20, 2010 5:53 pm    Post subject: Re: fuel pump not functioning Reply with quote
dont know bro...kat mana relay tu?
PostPosted: Wed Jan 20, 2010 5:55 pm    Post subject: Re: fuel pump not functioning Reply with quote
cuba ketuk itu fuel pump relay..
PostPosted: Wed Jan 20, 2010 6:06 pm    Post subject: Re: fuel pump not functioning Reply with quote
here it is (in red circle), your specs same as mine, so this is where fuel pump relay located, this part also holds aircond compressor relay. Inside the box, it contains 2 or 3 relay. the fuel pump relay is slightly longer. Brand new cost around RM75 to RM90, can try buy potong kereta for RM30
Good luck
PostPosted: Thu Jan 21, 2010 1:36 am    Post subject: Re: fuel pump not functioning Reply with quote
fuel pump relay prolly, beli le xtra simpan dlm kete, in case jadi lagi.
PostPosted: Thu Jan 21, 2010 4:31 am    Post subject: Re: fuel pump not functioning Reply with quote
checked..fuel pump relay ok....hahaha...apa lagi selain relay fuel pump?
faliq3201
PostPosted: Thu Jan 21, 2010 4:35 am    Post subject: Re: fuel pump not functioning Reply with quote
right bro highway...maybe that relay problem...dulu pernah kene,lupe plak..memamg betul kene simpan extra that relay selalu problem...klau tak silap BOSCH kan Laughing ...
