Online Now [1262]:
Visitors: 1261
Today: 141316
Total: 31099427
Fuel gauge
AERO
PostPosted: Sun Dec 20, 2009 4:57 pm    Post subject: Fuel gauge Reply with quote
Hi
Anyone can advice on how to check on the fuel gauge matter,as during driving it will shift from 30 liter to empty and then up only after sometime, and sometime it take longer for it to come up again.
Also the reserve tank light does seems to light up, how to check.
thanks
PostPosted: Mon Dec 21, 2009 6:48 am    Post subject: Re: Fuel gauge Reply with quote
All these problems might be your cable on the meter. Disconnect and reconnect again to get better connection, or, you might just clean the contacts with liquid solvent, WD40 will do the trick.
Your reserved light either blown or the cable not connected properly.
good luck
PostPosted: Mon Dec 21, 2009 4:06 pm    Post subject: Re: Fuel gauge Reply with quote
spot on, should be due to the connection.
AERO
PostPosted: Tue Dec 22, 2009 3:18 am    Post subject: Re: Fuel gauge Reply with quote
good luck
will try to clean it, by the way which connector are you refering for the reserve light.
Thanks
PostPosted: Tue Dec 22, 2009 10:39 am    Post subject: Re: Fuel gauge Reply with quote
good luck
Thanks
clean it all and the reserved light check the bulb
PostPosted: Tue Dec 22, 2009 11:13 am    Post subject: Re: Fuel gauge Reply with quote
past thread might be helpful
www.malatbimmer.com/ev...t=884.html
AERO
PostPosted: Wed Dec 23, 2009 1:33 am    Post subject: Re: Fuel gauge Reply with quote
Thanks again
Will try to remove the meter to check then, eeee any steps on what need to be taken out first before taking out the meter.
By the way my economy meter also not working how to trouble shoot it.
Thanks
