Online Now [1319]:
Visitors: 1319
Today: 51643
Total: 31162871
m40 timing belt set
AERO
PostPosted: Sat Oct 10, 2009 1:10 pm    Post subject: m40 timing belt set Reply with quote
hi
If anyone can assist my queries, am planning to change the belting of my m40 and would like to get more information on the price and also labour charges if possible.
1. timing belt
2. timing belt bearing
3. fan belt or air cond belt
Beside the belt also need to change the pads and also the bushes.
1. front pad
2. rear pad
3. what are the front bushing and $
4. what are the rear bushing and $
these are some of the item on my list to change.
Appreciate anyone could advice.
PostPosted: Sun Oct 11, 2009 12:21 am    Post subject: Re: m40 timing belt set Reply with quote
the timing belt set (belt and tensioner/bearing) should be around 60 bucks. add another 40 or so for the other belt. labour should be about 70 to 90.
all 4 pads will run you just over 200.
there's a recent thread that discussed all the types of bushings that one can replace. do a search man
AERO
PostPosted: Sun Oct 11, 2009 10:38 am    Post subject: Re: m40 timing belt set Reply with quote
thanks sure will do, i was quoated for the timing belt set alone cost me around 3++.
PostPosted: Mon Oct 12, 2009 2:16 am    Post subject: Re: m40 timing belt set Reply with quote
bro boonaroo....sure ar RM60 for the whole set of belt + bearing?
i recalled the belt a lone will cost RM45-50 wor??? unless I became another victim of the slaughter house la....
my case would be the same as AERO where the belt kit consists of belt, tensioner, 3 rings + an oil filters = RM300 +- lor....
PostPosted: Mon Oct 12, 2009 3:22 am    Post subject: Re: m40 timing belt set Reply with quote
My prices last time for M40:
Original BMW timing belt - RM210 (better quality than the OEM Contitech one which is RM70, up to you to decide if you want to get it)
Small bearing - RM50
Big bearing - RM55
Tensioner - RM100
Aircond belt - RM25
Power steering belt - RM22
Alternator belt - RM22
The 3 aux belts were Contitech brand. All prices from First Div, except for the tensioner, that one got through my mechanic, so dunno how much he added on for himself there.
PostPosted: Mon Oct 12, 2009 6:57 am    Post subject: Re: m40 timing belt set Reply with quote
I'm sorry guys, I assumed that the m40 parts would be similar to the m20 one that I'm using. I apologise if I've mislead anyone.
Go with nick, he's the guru for all things m40 : )
PostPosted: Mon Oct 12, 2009 4:08 pm    Post subject: Re: m40 timing belt set Reply with quote
timing belt SET? that must be together with oil seal, timing bearing, belt and 'o' ring...mmm slightly high though. Laughing
AERO
PostPosted: Tue Oct 13, 2009 2:20 pm    Post subject: Re: m40 timing belt set Reply with quote
Thanks for all the feedback, as i am not familiar of the price, that why now checking around, beside the belt,bearing,oil seal, is there such a thing as timing gear also that need to change together?
wow realy that cheap for M20 belt set....
Please advice.
PostPosted: Wed Oct 14, 2009 12:05 am    Post subject: Re: m40 timing belt set Reply with quote
Juz be reminded that belt alone cannot be RM300++....datz rediculous la bro....buy from reputable bimmer spare parts outlet like 1st Division, Munich Auto ...to name a few....
