Online Now [2057]:
Visitors: 2057
Today: 42709
Total: 31158404
headlamp E30
PostPosted: Thu Oct 08, 2009 11:49 am    Post subject: Re: headlamp E30 Reply with quote
ya btoi mr hway! kalo gune beras make sure basuh dulu kalo x mmg air kotoq tu melekat kat reflector nanti. Aku gune pasir tp halus & makan mase sikit nak wat tp menjadi jgak
PostPosted: Thu Oct 08, 2009 3:54 pm    Post subject: Re: headlamp E30 Reply with quote
bro highway...boleh ajar step by step x? saya budak baru belajar Razz
PostPosted: Thu Oct 08, 2009 8:59 pm    Post subject: Re: headlamp E30 Reply with quote
Hmm..btol..btol..btol... nanti bley DIY... headlamp m20 & m40 ada lain sket kan..??
PostPosted: Sun Oct 11, 2009 3:29 am    Post subject: Re: headlamp E30 Reply with quote
kalau possible...snap som picts during the process....berminat gak nak DIY mende ni....
i bot new headlamps...tot cud solve the un-terang-headlamp tu...tp wasted money!...yg br pon sama....
thanks!
PostPosted: Sun Oct 11, 2009 6:33 am    Post subject: Re: headlamp E30 Reply with quote
Done bro highway! Hahahaha... yesterday start the project.Really works la dude..
Thank you so much highwaystar.. Very Happy
PostPosted: Sun Oct 11, 2009 6:47 am    Post subject: Re: headlamp E30 Reply with quote
mmg original resipi turun temurun! i like Smile
PostPosted: Sun Oct 11, 2009 1:31 pm    Post subject: Re: headlamp E30 Reply with quote
bro..share la mcm mana nak buat... nak buka yg mana pun x reti ni... Razz
PostPosted: Sun Oct 11, 2009 11:36 pm    Post subject: Re: headlamp E30 Reply with quote
bukak slow² takut ada yg rosak nanti... nak bukak barang mekanikal ni x susah sangat pun.lg 1 try bukak cap dkt headlamp tu.mungkin ada gap sbb tula air/embun masuk.sbb tula cermin headlamp jd kelabu.seal la dgn gam gasket ke apa ke supaya jgn ada air/embun yg masuk.aku punya headlamp tu ada gap.patutla kelabu rupanya.dah seal pun.so should be ok after this.. Smile
PostPosted: Mon Oct 12, 2009 4:18 pm    Post subject: Re: headlamp E30 Reply with quote
there is no gap when you seal the headlamp, okay..logic speaking ehh...
your headlamp ada bleed area (where hot air escape) it located on each corner of the headlamp housing. ada lobang kecik. So, how does habuk masuk? satu hari 1 micron habuk..365 hari 365 micron masuk hahaha... kali bahagi dengan 20 tahun usia kereta??? beribu ribu micron masuk, bak kata kalau cecah habuk tuh dengan air buleh buat air kopi hahahaha...
dust will travel whenever your headlamp cools off. Hot air push the air out (when lamps is hot) and when it cold it sucks back in along with habuk2 jalan raya kat malaysia nih. If you stay in alaska yang mana kurang polution... your headlamp mesti terang punya..kekekeke
good luck!!!
PostPosted: Mon Oct 12, 2009 11:36 pm    Post subject: Re: headlamp E30 Reply with quote
Hahahahaha... yes bro absolutely correct..!!! Smile
