Online Now [2425]:
Visitors: 2425
Today: 168634
Total: 31114893
Spacers...
PaaN404040
PostPosted: Sun Aug 30, 2009 5:00 pm    Post subject: Spacers... Reply with quote
hai...
nk tanye...
ada ker spacer dari 4 hole ke 5 hole??
bole taw brape harga nya??
n kite punya rim tuh mmg pkai bolt ea
x mcm kete laen pkai nut??
btul kn sy if ada salah..
How We Saw The World
View user's profile Send e-mail Yahoo Messenger
PostPosted: Sun Aug 30, 2009 7:01 pm    Post subject: Re: Spacers... Reply with quote
from my experience, its better not to use spacer. It will cause vibration to the car.
Spend the extra money to get a proper bmw e30 rims. Its worth it.
IF you insist on using 5 hole PCD120 bmw rims. Do the 5 lug conversion and do it properly, do it once, do it right. Less headache
IF you again insist on using spacers, get a properly made spacers and dont cheap out on it.
PostPosted: Sun Aug 30, 2009 7:42 pm    Post subject: Re: Spacers... Reply with quote
I agree 100% on what Chris said...
PostPosted: Sun Aug 30, 2009 8:32 pm    Post subject: Re: Spacers... Reply with quote
can ask me maaa...kekekkeke....my Agong E30 is running on the 4 lugs to 5 lugs spacers. i nvr had any vibration issue. i spent 1.4K for the spacers and its a forever warranty hehehehe....no probs at all!
PostPosted: Sun Aug 30, 2009 9:59 pm    Post subject: Re: Spacers... Reply with quote
me using spacers too..but 4 lugs
no vibration whatsoever
fabricate your own instead of buying aftermarket ones
PostPosted: Tue Sep 01, 2009 6:30 am    Post subject: Re: Spacers... Reply with quote
Last time asking for spacer cost bout RM760 bro..
190/pcs.Better make a 5lugs conversion.Coz afraid if u r "kaki rembat" then the spacer will broken.Hehehehe... yeke bro jem? Agak² je ni..
PostPosted: Tue Sep 01, 2009 8:24 am    Post subject: Re: Spacers... Reply with quote
my spacers can handle 2000KG pressure wooo...fully tested:)
PostPosted: Tue Sep 01, 2009 1:54 pm    Post subject: Re: Spacers... Reply with quote
wow, can angkat 2 lori!
PostPosted: Tue Sep 01, 2009 11:05 pm    Post subject: Re: Spacers... Reply with quote
Then strict to wheel spacer la.more cheaper then conversion.Hehehehe..
PostPosted: Sat Sep 05, 2009 6:02 am    Post subject: Re: Spacers... Reply with quote
Saw this e34 rim in mudah, kinda ok to me, spacer or drill 4 hole?
www.mudah.my/BMW-Rim-E...501901.htm
bro PaaN404040, sorry hijack ur thred hehehe
PostPosted: Sun Sep 06, 2009 9:48 am    Post subject: Re: Spacers... Reply with quote
dont do it. you can drill to fit ONLY 318 E30, 318 single disc so caliper small, 320 vented caliper big. It will touch your inner side of the rim. Even if you shave the caliper..masih tak boleh. in the end still have to use spacer. oops unless you want to use spacer larr.
Okay i see the price for the rim is RM580, Spacer berapa? total with new set of tyres? suggest you to save extra money and get the correct rim.
been there done that.
PaaN404040 sorry hijack.
PostPosted: Mon Sep 07, 2009 3:32 am    Post subject: Re: Spacers... Reply with quote
hehehe, that's why i ask here, SPOT ON answer based on experience Smile
PaaN404040
PostPosted: Sun Sep 13, 2009 6:18 pm    Post subject: Re: Spacers... Reply with quote
wow...
pening nyer cm nih...
sy nk tuka coz ada mmbr da racun...
BMW E30 use bolt...
so die ckp tuka la pkai 5 hole nyer...
nnt bolt thn lama...
kalo 4 hole die ckp bolt x thn nnt patah dlm lagi susah...
tetambah da konvert RB20...
kick die laen mcm...
PostPosted: Mon Sep 14, 2009 12:44 am    Post subject: Re: Spacers... Reply with quote
Pegi kedai halfcut cari trailing arm ti je.. tu PCD 120.Kalo xnk beli spacer 4lugs kepada 5 lugs PCD 114.Janji duit ada.
PostPosted: Mon Sep 14, 2009 12:49 am    Post subject: Re: Spacers... Reply with quote
If you do not intend to change to 5-lug properly, then save up and get a good set of E30-specific rims.
If you use spacers, good quality ones are expensive, then you have to factor in the cost for longer lug nuts as well. Also, PCD converting spacers are quite thick, and will add unsprung weight to all 4 corners, decreasing performance. After all the cost + disadvantage, you might as well get proper rims. Razz
Just me 2 cents opinion. Wink
