Online Now [1389]:
Visitors: 1389
Today: 94538
Total: 30554354
e30 calibers
datsunnismo
PostPosted: Fri Aug 28, 2009 3:31 pm    Post subject: e30 calibers Reply with quote
hi all.
need some clarification.
pls differentiate between e30 318, 320 and 325 brake caliber, disc.
meaning to say, which disc can match with which calibers and all tht.
bro highway(super)star, need u here....
thanks
PostPosted: Fri Aug 28, 2009 5:21 pm    Post subject: Re: e30 calibers Reply with quote
first of all, you post into wrong topic lol
this topic should go to Car Talks.
anyway for E30
318 front non vented (solid disc),
Calipers smaller gap distance.
Rear Drum brake system
320 front vented disc
(thicker with ventilation flow in the middle of the disc looks like double disc size, this is to release heat and make the disc cooler faster than single solid disc).
Calipers will be bigger gap distance to fit vented disc.
323 and 325
front vented disc same as 320 but the
Rear is Brake Disc system using caliper also.
Bear in mind if you want to mode this from 318 to 325, you might need the 325 brake servo as well.
cheers!
ps evilnickwong care to continue hehehe??
PostPosted: Sat Aug 29, 2009 2:48 am    Post subject: Re: e30 calibers Reply with quote
Haha I have nothing to add on bro, I don't know much on brakes, just that my 318 has got stupid drums. Laughing
datsunnismo
PostPosted: Sat Aug 29, 2009 5:37 pm    Post subject: Re: e30 calibers Reply with quote
huh?!?!?!?!
servo between 318 - 325 also got different? my bad, i didnt know this.
how about the master?
PostPosted: Sat Aug 29, 2009 9:40 pm    Post subject: Re: e30 calibers Reply with quote
datsunnismo wrote:
huh?!?!?!?!
when you get servo, you get master also hehehe Laughing
datsunnismo
PostPosted: Sun Aug 30, 2009 4:58 am    Post subject: Re: e30 calibers Reply with quote
bro, i mean the master pump between 318 - 325 same or got different?
also whts the different like? the size of the servo or the innner part like diaphragm?
thanks for the input.
PostPosted: Sun Aug 30, 2009 7:44 pm    Post subject: Re: e30 calibers Reply with quote
actually normally when the brake servo has a certain size.. the master pump will have to come with it to it's proper mounting size...
