Online Now [1795]:
Visitors: 1795
Today: 135520
Total: 31093631
e30 front-end bushings replacement.
theduke
PostPosted: Wed Jul 08, 2009 4:10 am    Post subject: e30 front-end bushings replacement. Reply with quote
hi guys,
was wonderin' how much does it normally cost to replace the fullset of bushings for the front-end of e30?and wer is best to do it?
thanx in advance for any respond.
PostPosted: Wed Jul 08, 2009 4:21 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
Rough prices off the top of my head:
Standard front lower control arm bushing: RM30-35 each
or
Offset M3 front lower control arm bushing: RM75-90 each
Engine mounts: RM60 each (I think?)
Then you have transmission mounts as well, I'm not sure price for that.
Then also bushings for front ARB, make sure you get the correct size for your ARB, different E30s had different size ARBs.
Although to be honest, while doing those, you might as well take care of the ones at the rear: Laughing
Rear subframe bushings (2 pcs)
Rear trailing arm bushings (4 pcs)
Rear ARB bushings (2 pcs)
Rear differential bushing (1 pc)
PostPosted: Wed Jul 08, 2009 4:39 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
Offset M3 front lower control arm bushing <---good shit!
PostPosted: Wed Jul 08, 2009 4:45 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
chris.. you avatar needs bushing..kekekeke...
PostPosted: Wed Jul 08, 2009 5:04 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
Hehehehehe... yeah correct bro Smile
PostPosted: Wed Jul 08, 2009 6:39 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
or
good laundry list of things to do for ride refinement.
theduke
PostPosted: Wed Jul 08, 2009 6:46 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
or
thanx for the feed & info.any idea hw much does it cost overall?wat if for front only and for front and back?atleast i hav a comparison.n suugestion wer to do it?i stay near BU.
thanx.
PostPosted: Wed Jul 08, 2009 6:59 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
Hmm, rear subframe bushing were about RM70 each, and trailing arm bushings was RM55+ per pair (2 pairs), I remember the diff bushing is about RM50-60 or something.
When I did mine, labour was about RM150 for front + rear, but that included some additional work on changing all oil seals on my transmission and differential while it was down and a couple other things. I didn't change ARB bushings though.
PostPosted: Wed Jul 08, 2009 7:28 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
E30 6 cylinder engine
source Ortojaya Mentari Park Sunway
Front
ARB Ring Rod RM48 x 2 = RM96
ARB Bush RM25 x 2 = RM50
Engine Mounting RM40 x 2 = RM80
Lower Arm Bush M3 RM65 x 2 = RM130
Lower Arm Bush Normal RM33 x 2 = RM66
Rear
Swing Arm Bush RM75 x 2 = RM150
Trailing Arm Bush RM75 x 2 = RM150
ARB ring rod RM50 x 2 = RM100
ARB bush RM20 x 2 = RM40
Axle Bush RM65 x 2 = RM130
Axle Mounting RM90 = RM90
Workmanship Dunno, please check Optimum Kayu Ara
Ah Foo (owner) or Ah Fai (chief mechanic)
contact number dont have maybe others can help
cheers
theduke
PostPosted: Wed Jul 08, 2009 9:11 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
thank you..thank you all very much.. .
PostPosted: Wed Jul 08, 2009 10:42 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
wah, more than 1k, let's rob a bank.
PostPosted: Wed Jul 08, 2009 1:08 pm    Post subject: Re: e30 front-end bushings replacement. Reply with quote
Hmm..good info.
PostPosted: Wed Jul 08, 2009 1:36 pm    Post subject: Re: e30 front-end bushings replacement. Reply with quote
that is why i do in stages, wear and tear bukan semua sama. So just change whatever parts yang cepat rusak hehehe...
Suggest, diagnos your car and check all the bushing. so you can change the damaged part first. unless you already got Wooonggaaa!
PostPosted: Wed Jul 08, 2009 2:12 pm    Post subject: Re: e30 front-end bushings replacement. Reply with quote
mm..
just bought Axle Mounting @ RM110 (first division) huhu mahal gak..
PostPosted: Thu Jul 09, 2009 11:00 am    Post subject: Re: e30 front-end bushings replacement. Reply with quote
Hmm...harga dh naik le tu...
