Online Now [1752]:
Visitors: 1752
Today: 176186
Total: 31118669
What absrobers to match with lowered spring?
genozide
PostPosted: Fri Jul 24, 2009 3:05 am    Post subject: What absrobers to match with lowered spring? Reply with quote
Guys,
Been quietly reading all the forummers input and my you guys are definitely passionate about E30s... Very Happy Very Happy
I own a 1988 M40 325i four door. I am intend to refresh the suspension set since the previous owner made a rojak set up i.e.
Fr: H&R spring + Boge absorbers on 45mm struts
Rr: Original springs with Bilstein absorbers
I have sourced the 51mm front struts and brand new H&R springs...
I am confused on the which absorbers to go with...Can the sifus assist me here?
Secondly is it better to use thicker spring pad or use a thinner one...How low does H&R spring go?
Thanks in advance for the advise provided.
PostPosted: Fri Jul 24, 2009 3:42 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
If you are using lowered H&R springs, the best to match with it would be shorter sports absorbers. Yellow Bilsteins are the typical choice, about RM2.3k for a full set. You can get by with normal length black Bilsteins (OEM replacements) like me, but the ride will be abit bouncy as the OEM type absorbers can't cope with the higher spring rate of H&Rs.
For spring pad, all I know is you can remove it to go even lower, or add more if you wanna make the front or rear higher. H&R sports are not very low, mine still have about 2.5 finger front fender gap and 1.5 finger rear gap, with 205/45/16 tires.
Very Happy
Btw, is your ride M40 318i or M20 325i. Laughing
genozide
PostPosted: Fri Jul 24, 2009 3:55 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
Thanks sir Evil,
Mine is a 1988 M40 body with M20B25 engine...Originally imported from UK in 1992...Previously owned by a good buddy of mine...snatched it away from him when he wanted to overhaulin it...
Heard B6 Bilsteins are pretty hard on H&R... B4 would be okie... Confusion
How about Boge turbo/Sachs? Any comments
PostPosted: Fri Jul 24, 2009 4:27 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
get bilstein, u'll never regret it. xD
evilnickwong, why my car no gap ar?
*cabuts*
PostPosted: Fri Jul 24, 2009 4:30 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
that is because ur using the bilstein short stroke i guess hehehehe
PostPosted: Fri Jul 24, 2009 4:35 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
chris:
1) I remember you removed your spring pads. That's easily 10-15mm difference.
2) Your tires are 195/55/15 I believe which have a total diameter 5mm larger than my 205/45/16. That's another 2.5mm diff. Razz
Laughing Very Happy
PostPosted: Fri Jul 24, 2009 5:12 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
spring pads....what's the downside if you go without?
PostPosted: Fri Jul 24, 2009 7:51 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
evilnickwong, correct on the 2nd one though but i still retain my spring pads. xD
I read somewhere saying that without spring pads, the springs will move around and causing friction between the springs and the chassis? This is cause rust. THis is what i read la.
PostPosted: Fri Jul 24, 2009 8:14 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
Ooo then your springs must be a diff model Laughing
Yeah, I read that too. Without spring pads, it will be metal-to-metal contact which will wear off the springs coating and it will rust.
Also, there might be squeaking/clicking noise from the metal contact.
PostPosted: Fri Jul 24, 2009 8:39 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
slightly off topic from the original topic...sorry for that.
I've done some digging. reviews are mixed. some mirror what nick and chris are saying. others are claiming no issue at all. my conclusion, depends where you live and the climate. for us, where it rains a lot. prolly not the best idea.
theduke
PostPosted: Mon Jul 27, 2009 6:36 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
bro genozide,
u'v got pm.
PostPosted: Mon Jul 27, 2009 7:42 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
if im not mistaken, there are 2 types of spring pads, if u want to be lower, get the thinner ones. xD
theduke
PostPosted: Wed Jul 29, 2009 4:25 pm    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
paging for bro genozide...iv pm'd u..
theduke
PostPosted: Tue Aug 04, 2009 7:12 pm    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
anybody has Genozide's HP no?seem there's no reply in pm from him..
cheers.
PostPosted: Sat Aug 08, 2009 5:50 am    Post subject: Re: What absrobers to match with lowered spring? Reply with quote
Who was used Sach absober for lowed with any lowed spring?? Just want to know Sach performance for lowed setting. It's good or not?? I know gabriel & bilstein was a better choice.
