Online Now [1409]:
Visitors: 1409
Today: 142370
Total: 31100481
speedometer problem?
schwa
PostPosted: Sun Jun 21, 2009 1:53 pm    Post subject: speedometer problem? Reply with quote
hi,
need help here,
my speedmeter is not working,when i remove the meter only 2 cable attached to the socket,blue n white.
no cable attached to the green n yellow socket. is this normal or there is something missing?
rpm,temp n fuel meter is ok.
PostPosted: Sun Jun 21, 2009 4:48 pm    Post subject: Re: speedometer problem? Reply with quote
may i know what model is this? as for the pic, this is not from E30. E30 only attached Blue and white not yellow.
schwa
PostPosted: Sun Jun 21, 2009 5:06 pm    Post subject: Re: speedometer problem? Reply with quote
bro highwaystar,this is my e30 meter. yes it only attached blue n white. so is that normal?
any idea why my speedmeter is not working?
PostPosted: Mon Jun 22, 2009 12:22 am    Post subject: Re: speedometer problem? Reply with quote
yes..it is normal.only white n blue attached
as for speedo, maybe your sensor is faulty or the wiring itself
i can teach u how to check but r u a diy man & can do some wiring stuff?
schwa
PostPosted: Mon Jun 22, 2009 1:49 am    Post subject: Re: speedometer problem? Reply with quote
yes plz eau-rouge,how to check if it is sensor or wiring problem?
PostPosted: Mon Jun 22, 2009 1:55 am    Post subject: Re: speedometer problem? Reply with quote
Check out the cable plug on your diff too. Smile
schwa
PostPosted: Mon Jun 22, 2009 1:56 am    Post subject: Re: speedometer problem? Reply with quote
maybe my meter also got problem? sometimes the temp meter ok,sometimes it drop. the battery symbol supposed to lit before i start the car rite?
PostPosted: Mon Jun 22, 2009 2:21 am    Post subject: Re: speedometer problem? Reply with quote
mmm... i dismantle E30 meter before and yours is different. i dont what specs of your meter. E30 meter dont have the green part.
anyway look into this topic. maybe it helps
www.malatbimmer.com/ev...t=884.html
schwa
PostPosted: Mon Jun 22, 2009 3:59 am    Post subject: Re: speedometer problem? Reply with quote
thanx bro,i`m also thinking to spray this jarum2 but dont hav contact cleaner. now i know wd40 also can use,will try that tomorrow
PostPosted: Mon Jun 22, 2009 5:24 am    Post subject: Re: speedometer problem? Reply with quote
do that bro. most of us hv the experience. i've changed mine twice already:) now the meter go crazy again hehehehe...just ain't my luck yet.
schwa
PostPosted: Mon Jun 22, 2009 5:27 am    Post subject: Re: speedometer problem? Reply with quote
so this is a must hav experience for all e30 owner. hehe will try n keep u guys updated
schwa
PostPosted: Wed Jun 24, 2009 4:54 am    Post subject: Re: speedometer problem? Reply with quote
already try that method but the meter still not working iskk
PostPosted: Wed Jun 24, 2009 5:22 am    Post subject: Re: speedometer problem? Reply with quote
go potong shop and buy one, that is another option hehehehe
schwa
PostPosted: Wed Jun 24, 2009 7:50 am    Post subject: Re: speedometer problem? Reply with quote
how much does it cost aa bro jeembo? hard to find e30 parts here in kuantan. anyone hav spare meter to letgo pm me k
PostPosted: Wed Jun 24, 2009 7:56 am    Post subject: Re: speedometer problem? Reply with quote
i have 3 spares but sorry not letting it go bcos i plan to bring my E30 to the grave mauhahhhhahaaa....play E30 till i die:)
okay...some ppl got it cheap...some ppl got it reasonable and some ppl got it expensive. price ranges from RM150-RM400. make sure u test it first before deciding. bring ur car along to test. if ur confident, then buy it:)
