Online Now [1490]:
Visitors: 1490
Today: 109508
Total: 31067619
Clutch rest position
PostPosted: Thu May 28, 2009 5:46 am    Post subject: Clutch rest position Reply with quote
Quick question, here is a photo of my pedals:
The main thing is, my clutch sits much higher than my brake. Is there any way to adjust this to the same level? That distance is completely free play, the clutch only starts to have resistance after it goes below the brake level.
I heard can adjust the eccentric bolt (the one I circled), but not sure how?
PostPosted: Thu May 28, 2009 7:57 am    Post subject: Re: Clutch rest position Reply with quote
I too have this setup. always thought it was a little odd.
PostPosted: Thu May 28, 2009 8:17 am    Post subject: Re: Clutch rest position Reply with quote
I don't think it's normal, I have a thread on this over at r3v and most have their pedals at the same level.
PostPosted: Thu May 28, 2009 4:08 pm    Post subject: Re: Clutch rest position Reply with quote
don't think its normal meself. lemme know when you resolve it. : )
PostPosted: Fri May 29, 2009 7:54 am    Post subject: Re: Clutch rest position Reply with quote
my one not like this. Clutch and brake same level... mmmm
PostPosted: Fri May 29, 2009 8:02 am    Post subject: Re: Clutch rest position Reply with quote
Yalor, don't think it should be like this.
The bolt I circled in the picture, there is a dot or marking on it, can you check yours and see where it is pointed? I read it should be pointed either towards the engine or away from engine, 2 position only. But not sure, so I didn't go and adjust and see lol.
PostPosted: Fri May 29, 2009 8:06 am    Post subject: Re: Clutch rest position Reply with quote
I also dont know... have to open and see. BUT when i convert my auto to manual and saw the pedal before install, the pedal pops freely like spring (brake and clutch) I suspect its the cable, if the cable to long the clutch might be higher - Maybe only... will check and see.
PostPosted: Fri May 29, 2009 8:24 am    Post subject: Re: Clutch rest position Reply with quote
There is a cable? lol, I thought only got that spring that is hanging at the top there Laughing
PostPosted: Fri May 29, 2009 9:03 am    Post subject: Re: Clutch rest position Reply with quote
hahaha... mmmm it just my theory comparing with my fiat last time. BMW not using cable for clutch eh? mmm have to check
cheers!
Jumpman
PostPosted: Fri May 29, 2009 10:43 am    Post subject: Re: Clutch rest position Reply with quote
IT's definitely not normal. Mine are all sitting on the same level.
sakuragi
PostPosted: Fri May 29, 2009 2:27 pm    Post subject: Re: Clutch rest position Reply with quote
I had the opposite problem. My clutch pedal is just a little lower than the brake pedal. Well it's negligible i guess but certainly ain't looking good.
