Online Now [1567]:
Visitors: 1567
Today: 46230
Total: 31004341
a question for an answer
PostPosted: Sun May 24, 2009 4:03 pm    Post subject: a question for an answer Reply with quote
guys... nak tanya sikitla.bolehkah front and rear disc brake di "cross drilled"?? seperti yg diketahui disc layer mestilah double layer utk membuang haba panas.dan soalan yg seterusnya ialah boleh ke pakai steering rack E36 dan drive shaft Z3? pernah terbaca chris punya solution from 4 lugs into 5 lugs.boleh ke di 'convert' kan? Z3 drive shaft and E30 are the same spec? can fit into diff?
PostPosted: Sun May 24, 2009 4:42 pm    Post subject: Re: a question for an answer Reply with quote
Bro, this is not 'a question' nih, banyak nih. From my not so knowledgeable knowledge, here is my answer;
1. Cross-drilled a non-cross drilled disc? Can be done. Saw it before. But, u are jeopardizing ur own safety to do that. No short-cut for safety OK? The specs is not the same. My advice, get the ori cross drilled if u want.
2. Pakai E36 steering rack into E30. Can. No prob. U'll get more cornering ratio. Syiok! A lil' bit mod will be needed.
3. Z3 to E30. Macam pernah dengar. Need more facts bro. Maybe Chris can help =)
PostPosted: Sun May 24, 2009 11:30 pm    Post subject: Re: a question for an answer Reply with quote
Hehehehe... thank you bro.was thinking to cross drilled front and rear disc so that the brake will be more gippen... Smile now gonna get other optionla to buy that things.brembo disc ke?? Mati mcm ni... So chris how bout u?
can fit a Z3 into E30 ke??
PostPosted: Mon May 25, 2009 12:36 am    Post subject: Re: a question for an answer Reply with quote
Even factory cross drilled discs can eventually crack around the holes under hard usage. So sending your stock discs to be drilled by some random shop is not recommended. Go find some new Brembo slotted discs. Smile
PostPosted: Mon May 25, 2009 10:45 am    Post subject: Re: a question for an answer Reply with quote
ya change all new parts.
better to have some peace of mind Smile
PostPosted: Mon May 25, 2009 2:29 pm    Post subject: Re: a question for an answer Reply with quote
hehehehe.... ok.will consider that Smile
btw,thanks guys.
