Online Now [1836]:
Visitors: 1836
Today: 135729
Total: 31093840
steering rack leakiing
boyhartge
PostPosted: Sat May 09, 2009 4:12 pm    Post subject: steering rack leakiing Reply with quote
erlow guyz....
my steering rack sudah leaking both left n right....
ada sesape ada spare steering rack utk di jual???
my car e30 323....
or ada suggestion lain yg leh buat???
thanks....
datsunnismo
PostPosted: Sat May 09, 2009 5:33 pm    Post subject: Re: steering rack leakiing Reply with quote
e36 steering rack....................
boyhartge
PostPosted: Mon May 11, 2009 12:51 pm    Post subject: Re: steering rack leakiing Reply with quote
e36 steering rack???
kene ada mod or just plug n play bro???
how much??
PostPosted: Mon May 11, 2009 1:48 pm    Post subject: Re: steering rack leakiing Reply with quote
if not mistaken, few places will mod for you around Rm1k-1.2k. steering rack+workmanship
boyhartge
PostPosted: Mon May 11, 2009 2:54 pm    Post subject: Re: steering rack leakiing Reply with quote
wow....
if original e30 how much ek???
ada sesape ada???
PostPosted: Tue May 12, 2009 2:19 am    Post subject: Re: steering rack leakiing Reply with quote
boyhartge wrote:
wow....
ada sesape ada???
original E30 susah nak dapat dah. kalau dapat pun rege around 600 to 650 steel or alloy but most of it pun bocor gak. convert to E36 punya lah, E36 rack cost slightly lower mebbe around 450.
good luck!
nevets
PostPosted: Tue May 12, 2009 3:00 am    Post subject: Re: steering rack leakiing Reply with quote
miepower has one up for sale...
www.mudah.my/vi/3056930.htm?ca=11_s
bro if convert to e36 will it affect the 'feel' of an e30 which is much more desirable?
PostPosted: Tue May 12, 2009 3:44 am    Post subject: Re: steering rack leakiing Reply with quote
The E36 rack is usually more desirable as it has a tighter steering ratio which lends to a sportier/nicer feel in the steering.
If I'm not mistaken, E30 has 4 turns lock to lock, while E36 only has 3.5 turns. That's why alot of E30s do the conversion to E36 or Z3 steering rack.
boyhartge
PostPosted: Tue May 12, 2009 4:23 am    Post subject: Re: steering rack leakiing Reply with quote
orait2.....
tq frenz....
baru dapat call dr our member....
he said that it can be repaired....
i will try it first then i will update it here....
tq so much all my frenz....
peace
PostPosted: Tue May 12, 2009 5:13 am    Post subject: Re: steering rack leakiing Reply with quote
boyhartge wrote:
orait2.....
tq frenz....
peace
yes, repair using rack repair kit. see the condition first, some cases rosak dah teruk repair pun tak jadi. unless your friend can send for overhaul.
good luck
boyhartge
PostPosted: Tue May 12, 2009 5:28 am    Post subject: Re: steering rack leakiing Reply with quote
orait....
tq bro....
will look into it....
cheers....
nevets
PostPosted: Tue May 12, 2009 6:48 am    Post subject: Re: steering rack leakiing Reply with quote
thx for explanation NIck, will consider an upgrade then...hmmm Z3 as well????
