Online Now [1059]:
Visitors: 1059
Today: 92783
Total: 31203925
Weird Symptom
PostPosted: Tue Apr 14, 2009 12:28 am    Post subject: Weird Symptom Reply with quote
I have experienced some weird symptom from my car during the rush after working hours down town KL. Thought of sharing it here & perhaps someone here can share some thoughts what could the problem be...
As I drove out from basement car park, I have experienced lost of power as I try accelerating by pushing the paddle deeper Shocked
The engine didn't stall, didn't die off, but the rpm maintain around 1100rpm with smooth sailing speed climbing the slope regardless of how hard I push the paddle.
After I made it to the main road along jalan ampang, I joined the car flow but still unable to accelerate. The rpm was around 900-1000 without engine stall or die off...slowly crawl its way while the long queue of cars behind me flashing their headlamp urging me to move faster...
I decided to give up, pulled the car one side, disengaged my gear, start to rev the car a bit, to my surprise, this time the rev react positively according to my paddle, everything seems normal though...
Again, engaged the gear & re-start my journey ...however, the car simply won't move no matter how hard I push the paddle trying to accelerate...the rpm stayed at 900 without any throttle response from the paddle...the feeling is as if I am stepping on a vacum paddle without any response from the engine Confused
After a long 3 minutes of drag along the main road, the car out of sudden back to normal, throttle response returned & the car accelerated till reached home.
This morning oso okay without any problem... Confused
Why eh? Question Question Question Question Question Question Question Question Question Question Question Question Question Question Question Question
PostPosted: Tue Apr 14, 2009 12:38 am    Post subject: Re: Weird Symptom Reply with quote
Your e30 caught you looking at a newer bimmer in the car park as you walked to it. Didn't you! Laughing
OK, but seriously, I no idea also lol, I've never encountered this myself.
PostPosted: Tue Apr 14, 2009 1:10 am    Post subject: Re: Weird Symptom Reply with quote
addooii... this must be it..heehhee
let me reconfirm, did your auto gear shift during that time?
i reckon something got to do with electrical.
please send to service centre and check your gearbox response ie step shift, cable bla bla, oil gear service and also electrical components ie ECU. maybe they can calibrate from there.
i also never face this problem before.
eezuan
PostPosted: Tue Apr 14, 2009 1:49 am    Post subject: Re: Weird Symptom Reply with quote
ive encountered this problem also...
but i had my fuel pump cracked,,,(the motor running fine)
sometimes ok sometimes like yours..
until the pump koyak only i knew the fuel pump problem..
check the fuel pressure nearby the fuel regulator, tahan with your thumb,
if you can tahan means your fuel pump...:)
hihohiho
PostPosted: Tue Apr 14, 2009 5:13 am    Post subject: Re: Weird Symptom Reply with quote
bro highway : no throttle no gear shift at all, seem like stepping on hollow paddle, gear stayed at 1st with idle rpm, crawl itz way at snail pace...(as though u release the brake & let the car slide on its idle speed-auto gear...)
bro eezuan : tks for the sharing, wil do the checking on my fuel pump!
PostPosted: Tue Apr 14, 2009 5:41 am    Post subject: Re: Weird Symptom Reply with quote
if no gear shift must be gear valve body, but strange, if cannot shift gear, you able to rev freely. but your case dua dua pun takleh. and kejap ada kejap takde... aihhhh... pelik2. will check around
PostPosted: Thu Apr 16, 2009 12:42 am    Post subject: Re: Weird Symptom Reply with quote
tks bro highway...
PostPosted: Mon Apr 20, 2009 12:54 am    Post subject: Re: Weird Symptom Reply with quote
an update for record & sharing sake...
Last Saturday morning, planning to send my car to mech for checking as well as periodical lube service, as I drove out of my hse, the car gave the same problem intermittently from usj to pj...
the timing was right as i almost reach my mech worskshop, the car has come to total halt & was not able to gain throttle response. so slowly let the car slide for 500m frm main road to workshop...
aftre the mech gave a thorough check, he concluded that it was the fuel filter that gave the problem.
After changing it, the car was smooth ride til now...will continue to monitor to see if the same symptom wll occur again.
PostPosted: Mon Apr 20, 2009 3:07 am    Post subject: Re: Weird Symptom Reply with quote
hehehe had this prob with my wira long time ago....but it was due to throttle body...
but no experience with my E30.....good info nawty!
