Online Now [1961]:
Visitors: 1960
Today: 156362
Total: 31108757
E30 sedan rear window motors
PostPosted: Mon Mar 30, 2009 8:37 am    Post subject: E30 sedan rear window motors Reply with quote
Hi, does anyone know what the typical price is for used/chopshop rear power window motors? Mine jammed already, and even after opening up to clean, lube, etc still doesn't work. Sad
Would just like to know the general idea. If pricey, then fook it, my rear windows are staying up forever. Laughing
PostPosted: Mon Mar 30, 2009 9:03 am    Post subject: Re: E30 sedan rear window motors Reply with quote
bro.. is the wire got its power of not?
PostPosted: Mon Mar 30, 2009 9:05 am    Post subject: Re: E30 sedan rear window motors Reply with quote
Got. The motor will make sound when I press the up or down buttons. Also, the up movement sometimes works. But the down usually cannot. Smile
PostPosted: Mon Mar 30, 2009 9:07 am    Post subject: Re: E30 sedan rear window motors Reply with quote
wokei.. will check fer you
PostPosted: Mon Mar 30, 2009 9:10 am    Post subject: Re: E30 sedan rear window motors Reply with quote
try to look this thread... might helps.
cheers
www.crunchyfrogpro.com...epair.html
PostPosted: Mon Mar 30, 2009 9:41 am    Post subject: Re: E30 sedan rear window motors Reply with quote
Haha that's the DIY I followed. I cleaned the motor plates of all the rust already too. Opened up the black housing to check the gears too. But end result after all that still cannot work. Sad
PostPosted: Thu Apr 02, 2009 5:16 am    Post subject: Re: E30 sedan rear window motors Reply with quote
Motor Winder Rear
M20 RM150 availability YES
M40 RM250 availability NOT CONFIRM
Call me ahh
PostPosted: Thu Apr 02, 2009 5:27 am    Post subject: Re: E30 sedan rear window motors Reply with quote
RM250 for one? I think I leave it as fixed position windows adi lol. Got more important things to attend to then haha.
PostPosted: Thu Apr 02, 2009 5:36 am    Post subject: Re: E30 sedan rear window motors Reply with quote
hahaha.. okey bro... lucky you're not using E34, change mine before
cost 400 hahaha kantoi.
anyway, they give complete assembly with the lifting gear also (NOT ONLY MOTOR). anything calling2 lah.
PostPosted: Thu Apr 02, 2009 7:56 am    Post subject: Re: E30 sedan rear window motors Reply with quote
hi highwaystar,
where was this window motor repair you mentioned? I wouldn't mind paying 150 to get mine fixed. its sorta stuck with 1 inch open. its ok when you're in town but on the highway, its a different story.
thanks.
PostPosted: Thu Apr 02, 2009 8:41 am    Post subject: Re: E30 sedan rear window motors Reply with quote
boonaroo wrote:
hi highwaystar,
thanks.
its not fix... its use spare parts.
PostPosted: Thu Apr 02, 2009 9:10 am    Post subject: Re: E30 sedan rear window motors Reply with quote
I see....
mine's the cable version to be exact. do you know if there's available spares? I'd def be interested.
thanks
PostPosted: Thu Apr 02, 2009 9:15 am    Post subject: Re: E30 sedan rear window motors Reply with quote
boonaroo wrote:
I see....
thanks
give me yer specs
car what year? e30 e21?
i'm going to get caliper for xsjado tmmr. might check fer you too.
cheers
PostPosted: Thu Apr 02, 2009 9:31 am    Post subject: Re: E30 sedan rear window motors Reply with quote
hey thanks a lot man.
mine's a '84 E30.
much appreciated.
PostPosted: Thu Apr 02, 2009 9:41 am    Post subject: Re: E30 sedan rear window motors Reply with quote
mine's a '84 E30.
much appreciated.
bro rear front left right?
call me direct please 0178793243
