Online Now [1991]:
Visitors: 1991
Today: 88351
Total: 31199493
Hunting Idle
eezuan
PostPosted: Mon Apr 06, 2009 8:12 am    Post subject: Re: Hunting Idle Reply with quote
Ok, change the box to 525,afm 525, and icv 525 already..
the results, the engine sound like racing cam.. from 650rpm up to 1100k rpm,
then, the mech sets the afm and tps, the rpm went to 650k and stable... but the response happen like last time, lagging for 1-2 seconds.. push the paddle, the car didnt go, after a while oni it responsed. no power and no torque at 4k - 5.5k rpm. very lean.. no power at all..
my current 520 box is better, power full.. but only the idle is quite high..
if the car moves, and i put on the free gear, rpm went to 1200k ,and when the car stops, it went to 950k rpm...
adus!! memang minyak terasa kuat....
hihohiho
PostPosted: Mon Apr 06, 2009 8:58 am    Post subject: Re: Hunting Idle Reply with quote
bro before you do this, did you diagnose computer check? if yes what error stated?
eezuan
PostPosted: Mon Apr 06, 2009 9:07 am    Post subject: Re: Hunting Idle Reply with quote
No, i didnt, where can i do the diagnose and to get error code?(the place)
hihohiho
PostPosted: Mon Apr 06, 2009 9:09 am    Post subject: Re: Hunting Idle Reply with quote
any bmw specialist ada benda nih.... yu can also try optimum
PostPosted: Mon Apr 06, 2009 10:20 am    Post subject: Re: Hunting Idle Reply with quote
eezuan wrote:
first of all would like to thank you and really appreciate to all of you guys for giving opinions.
ok, i will tell what i have already done for the engine. The story will be quite long... hehe..
1. the original engine was 520 manual 12 valve(rpm was 950k)
2. change the 525 engine (only head and block)(same rpm 950k)
3.change 525 afm,throtle body,injectors(still rpm 950k)
4.change all new hoses.(still rpm 950k)
5.change computer box 525.(rpm 600 but the throtle responsed was delayed badly, when push accelerator, the engine lag for few seconds the only it responsed even tho after tuned afm,tps and throtle screw. the fuel consumption was good using 525 comp box. but the driving was sucks!and no power)
6.so, i change back the 520 comp box. everything was fine, only the rpm is higher than normal and fuel consumption very bad. full tank oni can go up to 250km- 270km! )there was one time i had the perfect tune which the rpm was 650k(i dunno suddenly like that for two months after that back to 950k rpm).... during that time my car can go up to 600km full tank.
7. lastly,changed fuel regulator.still the same Sad
actually u did the right thing cos u need to change all parts to 525 spec when u do d conversion ......But i found out u left something there ...have u change ur fuel injectors to 525 one ??
525 cant run on 520 ECU ......ur mapping will be no be tune properly .....
eezuan
PostPosted: Tue Apr 07, 2009 6:10 am    Post subject: Re: Hunting Idle Reply with quote
yeap lionel, ive change the throtle body as well as intake manifold and injectors 2.5..
hihohiho
PostPosted: Tue Apr 07, 2009 9:51 am    Post subject: Re: Hunting Idle Reply with quote
how about o2 sensor?
PostPosted: Tue Apr 07, 2009 9:59 am    Post subject: Re: Hunting Idle Reply with quote
O2 sensor is chris' best friend. Laughing
eezuan
PostPosted: Wed Apr 08, 2009 12:13 pm    Post subject: Re: Hunting Idle Reply with quote
o2 sensors also has changed. no different.:(after change o2 sensor the fuel consumption a bit lower, but the rpm still at that 950k ...
hihohiho
eezuan
PostPosted: Tue Apr 14, 2009 2:01 am    Post subject: Re: Hunting Idle Reply with quote
Still not solve.. but my fuel consumption much better,,
but it because of leaking at the fuel pump round rubber sealed.
but my rpm still like that..
hihohiho
eezuan
PostPosted: Wed May 27, 2009 3:21 am    Post subject: Re: Hunting Idle Reply with quote
ok guys... i have already solved my prob!!!!
it was the relay in the fuse box.
i took out two relays which related to air cond.
compared to most of m20 engine for e34's, they are not using the relays.
so... after took out the relays, my rpm went to 600 already..
and.,.. my fuel consumption much much more lower!!! yahoo!!!! very happy already!!!!! yeahhaaa..!!!!!
hihohiho
PostPosted: Wed May 27, 2009 3:33 am    Post subject: Re: Hunting Idle Reply with quote
woaaahhh... so aircond not working?
btw CONGRATS BRO thanks for sharing.
eezuan
PostPosted: Wed May 27, 2009 3:02 pm    Post subject: Re: Hunting Idle Reply with quote
my air cond working fine... everything is fine now! perfecto!!! Smile
hihohiho
