Online Now [1358]:
Visitors: 1358
Today: 135006
Total: 31093117
MWTB : M44 engine + parts
abcd
PostPosted: Wed Mar 11, 2009 10:20 am    Post subject: MWTB : M44 engine + parts Reply with quote
Looking to swap my M401.6L with a M44 1.9L + necessary parts (eg timing chain, oil sump etc)
Interested sellers plse PM price of individual parts and item location
Thks
PostPosted: Wed Mar 11, 2009 11:06 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
m44 is it IS 318?
if i'm not mistaken got 1 for sale. 3k
abcd
PostPosted: Wed Mar 11, 2009 3:06 pm    Post subject: Re: MWTB : M44 engine + parts Reply with quote
m44 is it IS 318?
I think its a 1.9L (from a Z3). Laughing
Thks bro
PostPosted: Thu Mar 12, 2009 3:37 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
mmmm... its an IS engine nih.
"The M42 engine was modified slightly (mainly in the inlet manifold design) and fitted to the E36 318iS. It was subsequently developed into the M44 engine (1.9 litres) used from 1995 onwards. Note that the M44 used followers between the cams and tappets instead of the M42's directly actuated design and a plastic, variable inlet manifold. This engine had improved mid range but lacked the top end punch of the earlier engine."
abcd
PostPosted: Thu Mar 12, 2009 3:50 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
Thanks Bro!
If I want better low to mid end pick up, is the M42 1.8 IS engine better then (& easier and cheaper rite?)
Very Happy
So can enlighten
PostPosted: Thu Mar 12, 2009 4:53 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
Thanks Bro!
Very Happy
So can enlighten
easier yes... just swap the whole thing coz m42 fitted with anti-hijack ecu (EWS). Cheaper? i dont think so.. average around RM5k
So, if you wanted to bore your engine and fitted M44 crank set/shaft/pistons then consider a standard overhaul cost. BUT to get required parts you have to get engine kosong on which will cost you another 3k. Then you can salvage what ever parts that you need.
My suggestion, use your existing engine, balance your engine, port and polished, lighten your crank pulley then you're ready for cucuk-king heheheheh
abcd
PostPosted: Thu Mar 12, 2009 5:32 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
[/quote] So, if you wanted to bore your engine and fitted M44 crank set/shaft/pistons then consider a standard overhaul cost. BUT to get required parts you have to get engine kosong on which will cost you another 3k. Then you can salvage what ever parts that you need.
[/quote]
Bro
U mean keep my M40 and swap the crank set/shaft/pistons with a M44 set/shaft/pistons? Will this be a straight swap or more machining work need to be done to my M40 to fit in the M44 parts?
Is this part of a std engine overhaul cost? what is the expected mkt cost?
many thanks!
abcd
PostPosted: Tue Mar 17, 2009 3:44 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
m44 is it IS 318?
Bro
U know someone selling a M42 1.8L IS engine + complete wiring etc for complete swap?
item location?
thks Very Happy
PostPosted: Tue Mar 17, 2009 8:24 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
Location in Melaka bro... will check for availability. if still got i will pass you the number for you to liaise with. Tunggu ya!
abcd
PostPosted: Tue Mar 17, 2009 8:31 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
many thanks bro! Very Happy
PostPosted: Wed Mar 25, 2009 6:43 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
Got it.. it is still available. Timing Chain
This engine NO KEY only wire ECU and engine.
This fella said its 3k.
Location Malacca you can call him directly to deal/view
Indra 0123436023
good luck
abcd
PostPosted: Wed Mar 25, 2009 6:46 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
kam sia bro!
PostPosted: Wed Mar 25, 2009 6:55 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
abcd wrote:
kam sia bro!
no prob. sorry for delay.
later your ride will become like xsjado
abcd
PostPosted: Wed Mar 25, 2009 7:06 am    Post subject: Re: MWTB : M44 engine + parts Reply with quote
oh yes.
thks for the pic!
