Online Now [1534]:
Visitors: 1534
Today: 78381
Total: 31189523
Need help, my m20b20 l-jet rev cut at ~5500rpm
PostPosted: Sun Mar 29, 2009 10:46 am    Post subject: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
Greetings sifus and grand sifus, i've read through quite a lot of forum and wikis and all of it mentioned m20b20 rev limit is at 6500rpm. If that's the case then what's causing mine to cut-off at around 5500rpm? Clogged fuel filter? Dirty injectors? or maybe spark plugs need replacement? Confused
PostPosted: Sun Mar 29, 2009 5:58 pm    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
b4 anything , just bring ur car to the mech n check all the sparks, battery, ..fresh oil change all around ..new air filter/oil filter .
this is assuming u havent done a full service for the car .
it's a good idea also to check the injectors ,
i believe Optimum workshop has injector cleaning machine also .
ya ur engine shouldbe revving
to 6k rpm with no prob at all .
hope this helps
PostPosted: Mon Mar 30, 2009 12:49 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
my l-jet no cut off... most motronic does. go to mech and have it diagnose.
cheers
PostPosted: Mon Mar 30, 2009 6:21 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
cheers
ermmm, no cut-off for all l-jet or some mod required? Twisted Evil
PostPosted: Mon Mar 30, 2009 8:53 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
i dont even recall that ljet got cut off. mmm... mine when i bought no cut off lah... lemme check
eezuan
PostPosted: Mon Apr 06, 2009 9:12 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
hello, as far as my experience, that is because off the afm spring is too loose, and it will over supply the fuel and you'll have the cutt off early..
that what i have experienced before la.. Smile
hihohiho
PostPosted: Mon Apr 06, 2009 10:09 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
i think its not a cut off ......wat u feel is after 5000 rpm ur cant rev anymore ....
Many reasons cause tat happened .....
Check from most simple thing like fuel filter , injectors and air filter ....
I face d problem and found out its my open pot damm dirty and block d air flow ...so not enuf for d combustion ........rev stuck at 5000 rpm ....
PostPosted: Thu Apr 23, 2009 4:28 pm    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
any way to adjust? or have to get spare afm Sad
PostPosted: Thu Apr 23, 2009 4:33 pm    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
replaced fuel filter(rm40, expensive?) but still stuck at 5500 though rev smoother at lower rpm. will proceed to remove filter later when free.
eezuan
PostPosted: Fri Apr 24, 2009 6:23 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
where u stayin? mind to meet up?
hihohiho
PostPosted: Fri Apr 24, 2009 8:37 am    Post subject: Re: Need help, my m20b20 l-jet rev cut at ~5500rpm Reply with quote
damansara damai. meetup? surely can Very Happy
