Online Now [1781]:
Visitors: 1781
Today: 100298
Total: 31058409
Anti Roll Bar (ARB)
PostPosted: Thu Jan 15, 2009 7:43 am    Post subject: Anti Roll Bar (ARB) Reply with quote
wanna ask a question here regarding ARB...
was thinking to buy ARB fit it onto my E30 323....when i made inquiry to this seller that published his rear ARB for sale, he said all E30 has factory fitted ARB & I don't need to buy it?????
Huh?
I tot ARB is after market performance enhancement tool???
Confuse le....
PostPosted: Thu Jan 15, 2009 8:14 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
if not mistaken, m20b25 have stock arbs. for newer facelifted cars such as m40, they dont have.
PostPosted: Thu Jan 15, 2009 9:30 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
ARB for 323 already got as standard... size same as 325. except 318 and maybe 320
PostPosted: Thu Jan 15, 2009 9:55 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
tks a lot bros for the clarifications!
dat save my pocket for some other goodies! Razz
PostPosted: Thu Jan 15, 2009 10:01 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
first of all did you check whether you got arb or not?
PostPosted: Thu Jan 15, 2009 11:27 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
Idea Eeeerrrr...dat part i hv not tot of....will get it check this weekend....
PostPosted: Fri Jan 16, 2009 2:23 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
Sad case 318i do not come with rear ARB. Which is why my car is like a boat in corners.
Just go look under your car from behind and see if you can spot the ARB or not. Smile
If not, time to look for linkages + brackets + ARB. Very Happy
PostPosted: Fri Jan 16, 2009 2:46 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
i m not sure if i can identify it...will try to look at it...tks anyway for the hint!
PostPosted: Fri Feb 06, 2009 6:17 pm    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
e30 mesti ada ARB ...kuasa arb mah .. Very Happy
my car 320 originally dont have rear arb ... but installed rear arb using e30 325 rear arb a long time ago.
does help significantly if u're a spirited driver.
PostPosted: Mon Feb 23, 2009 11:18 am    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
Dude,hijack jap! If using the ARB and also the polyurethane bushes is it good??
I heard that bushes is good for handling isnt it.cost bout RM900 per set je.(8 bushes only)
wanna buy it last month but economy prob.. Hehehehe.... Smile
baba
PostPosted: Thu Mar 19, 2009 2:50 pm    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
Hear that local aftermarket ARB for E30 oso selling...If baba not mistakes it's from brand that called Super racing or Ultra racing...something like that....so baba want to know it's same size with original ARB for E30?? How bout da material & it's good choice for our E30??? (that not have ARB likes baba car)
PostPosted: Thu Mar 19, 2009 3:47 pm    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
the brand is ultra racing...local brand. Im using it myself, not bad. The front is 22mm, the rear is 19mm. Stock? im not sure.
Arbs is so worth it, it really transformed the car in terms of handling, very very obvious. xD
PostPosted: Thu Mar 19, 2009 5:26 pm    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
boy_mtech: RM900 a set I assume you are referring to all OEM. Yes, if your bushings are all worn out, then changing them all can yield good improvement.
For ARBs, Ultra Racing changed their front bar specs recently. It's now 20mm front, 19mm rear and I have been quoted RM700 for both.
Of course, if you feel that there is more to ARBs than just bar diameter, you can opt for Eibach or H&R, but both those will be RM2x00 per set. Laughing
PostPosted: Thu Mar 19, 2009 6:53 pm    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
that is very cheap. buy buy buy!
PostPosted: Fri Mar 20, 2009 12:37 pm    Post subject: Re: Anti Roll Bar (ARB) Reply with quote
Very Happy ..watever u put in ur car, ..tires matters the most Smile
highwaystar, NCT5 ..kekekeke
