Online Now [1944]:
Visitors: 1943
Today: 55040
Total: 31166182
Something I should Worry????
PostPosted: Wed Jan 28, 2009 1:40 am    Post subject: Something I should Worry???? Reply with quote
been emitting lotza smoke during the morning start up....
anything should I be worried here?
PostPosted: Wed Jan 28, 2009 1:47 am    Post subject: Re: Something I should Worry???? Reply with quote
me too.....it has been quite a while.....
and smell of petrol inside the car........
PostPosted: Wed Jan 28, 2009 1:59 am    Post subject: Re: Something I should Worry???? Reply with quote
oi bro amna, pls check the fuel float of ur car if your interior smells petrol....my previous white coupe was suffering the same problem, after got all the hose checked, no leaks found.....finally found the culprit was with the fuel tank float!
as for the smoke, i smelled too rich of fuel mixture....funny it only happens on the mrgbut not other time???
PostPosted: Wed Jan 28, 2009 2:07 am    Post subject: Re: Something I should Worry???? Reply with quote
ooo ya ka? tq...will ask d mech to check on it....
maybe your car giving you a sign....dont ignite him in d morning la...wait until 12 la....hehehe...i punye if tak start lama..doesnt matter wat time...the smoke come out.....
PostPosted: Wed Jan 28, 2009 2:15 am    Post subject: Re: Something I should Worry???? Reply with quote
hahahaha...nevermind, i hope it send me the engine failure signal! so i can convince my HM that itz time the car needs a new HEART!
HAHAHAHA....325 is the aim!
PostPosted: Wed Jan 28, 2009 2:18 am    Post subject: Re: Something I should Worry???? Reply with quote
bro i heard beginning 2009.....only 20% increment of CC wud b apruv by JPJ..... dunno la...
anyway gd luck!
PostPosted: Wed Jan 28, 2009 2:39 am    Post subject: Re: Something I should Worry???? Reply with quote
no prob wor, my current cc is 2.3, given 20%, I can go up till 2.76....
so i dun foresee myself having trouble with that new ruling by upgrading to 2.5 ....
PostPosted: Wed Jan 28, 2009 2:41 am    Post subject: Re: Something I should Worry???? Reply with quote
then u sell to me 2.3 cheap2 one lorr....i wan to upgrade olso....
PostPosted: Wed Jan 28, 2009 2:50 am    Post subject: Re: Something I should Worry???? Reply with quote
hmm...sounds a good deal...ok, wait for my bajet set ya...kalau jadi, better still, i can save a bit on the conversion, less pain Laughing
puddycat
PostPosted: Wed Jan 28, 2009 3:24 am    Post subject: Re: Something I should Worry???? Reply with quote
it's your valve seals... the oil leaks down during the night into the chamber, hence when u start the car, the oil gets burned up. so it's old now, a new set will cure it.
unless the morning is cold, the air in the exhausts mixes with the exhaust fumes or the your engine is very good in the morning, or it shows that the cold start valve is working in your car...
PostPosted: Wed Jan 28, 2009 3:50 am    Post subject: Re: Something I should Worry???? Reply with quote
tks bro puddycat....i sure hope the latter explanations of yours strike my case...
anyway, to be on the safe side, letz get my valve seals check la...TQ!
