Online Now [2679]:
Visitors: 2678
Today: 54139
Total: 30454670
weight,diff oil & hp...
PostPosted: Sat Feb 14, 2009 11:56 am    Post subject: weight,diff oil & hp... Reply with quote
guys.. Nak tau berapa berat keseluruhan body E30 sedan including engine etc,brand minyak LSD yg bagus and berapa kadar hp utk m20b20 engine (standard without modified).
TQ.. Smile
PostPosted: Sat Feb 14, 2009 1:53 pm    Post subject: Re: weight,diff oil & hp... Reply with quote
errr hijack!!!!brapa weight diff oil yang anda semua guna????
PostPosted: Sat Feb 14, 2009 2:06 pm    Post subject: Re: weight,diff oil & hp... Reply with quote
last i checked , ..roughly
e30 320i stock ..kerb weight is bout 1000-1100kgs (roughly)
stock bhp is bout
123-129bhp @4000rpm .depending on year of the engine produced.
stock torque
165nm-174nm @4000/4300rpm. depending on year of engine produced.
When the E30 debuted in 1982, the 2.0 was fitted with Bosch L-Jetronic fuel injection and the revised "731" cylinder head featuring larger intake ports. In 1987, the 2.0 was again revised with the addition of Bosch Motronic engine management and a catalytic converter.
not the most exciting engine , but can be fun if driven spiritedly Smile
PostPosted: Sat Feb 14, 2009 6:26 pm    Post subject: Re: weight,diff oil & hp... Reply with quote
so that means not too much hp la in m20b20 stock engine.then if put some mod maybe can increase the hp rite.ok bro thanks.
what bout the lsd oil? what brand is better?
PostPosted: Sat Feb 14, 2009 9:00 pm    Post subject: Re: weight,diff oil & hp... Reply with quote
redline LSD oil...nothing else
PostPosted: Sun Feb 15, 2009 7:10 am    Post subject: Re: weight,diff oil & hp... Reply with quote
if u ask me , m20b20 is a decent engine , but the Ljetronic management is bit unstable and rough ..need retune of the air/fuel ratio after a while.
tapi kalau u wanna mod that engine . i'd advise ..baik carik m20b25 je .
you get more hp and torque plus Motronic management.
Smile
PostPosted: Sun Feb 15, 2009 8:24 am    Post subject: Re: weight,diff oil & hp... Reply with quote
ok its a good advice.so the redline oil is the 1 la ni? ok thanks chris.
xnak swap others engine.. just keep the originality.maybe a lil bit like change the intake manifold kot... or resize the throtle body.. Hmmm... thats all.depends on calculationla.
PostPosted: Sun Feb 15, 2009 8:33 am    Post subject: Re: weight,diff oil & hp... Reply with quote
change the gearbox oil to redline as well. Its ridiculously good
PostPosted: Sun Feb 15, 2009 9:10 am    Post subject: Re: weight,diff oil & hp... Reply with quote
wanna keep ori ah ... mmm
use 325 throttle body ..then find alpina/hartge replica headers..pun ok gak .
PostPosted: Sun Feb 15, 2009 9:48 am    Post subject: Re: weight,diff oil & hp... Reply with quote
Oowwhhh... thats y la im asking bout the weight and hp bro.saje je nak buat calculation.hehehe...
nak sedap atas highway je actly,bknnya apa pun....and also some testing Smile
PostPosted: Mon Feb 16, 2009 5:26 am    Post subject: Re: weight,diff oil & hp... Reply with quote
chris macam redline ambassador saja. XD
PostPosted: Tue Feb 17, 2009 3:07 am    Post subject: Re: weight,diff oil & hp... Reply with quote
why not eh chris? hehehhe
side track.. where did you normally buy redline oil chris?
PostPosted: Tue Feb 17, 2009 4:09 am    Post subject: Re: weight,diff oil & hp... Reply with quote
So far I've seen it in Eneos 1U and KakiMotor Mid Valley. Very Happy
PostPosted: Tue Feb 17, 2009 9:14 am    Post subject: Re: weight,diff oil & hp... Reply with quote
i bought my oils in Eneos 1U, 1 bottle is RM55. The price is fixed no matter where and what type of oil.
PostPosted: Tue Feb 17, 2009 2:41 pm    Post subject: Re: weight,diff oil & hp... Reply with quote
man i have to fly to kl to get it....checking for how many litres to fit into my small case
