Online Now [2607]:
Visitors: 2607
Today: 172000
Total: 31116576
E30 M20 L-Jetrionik Conver To Motoronik?
PostPosted: Wed Nov 19, 2008 8:04 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
once again, m52 turbo=hantu
PostPosted: Wed Nov 19, 2008 10:26 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
yep , m52 turbo = gHost in a shell .. =)
depends what u want , u want power vs handling or power with handling ,
so many cara to do it , too much power , handling sure kacau .
let's not forget it an e30 chassis . not some new e46 chassis .
gotta think about the poor old 'bird' also .
puddycat
PostPosted: Fri Nov 21, 2008 2:40 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
what ? want to match a M50 power... easy, dun need to sweat so much or burst your piggy bank...
1. put in a 2.7 block bottom end, make sure it's the 9.8 cr pistons.. need to buy new. blue print the engine.
2. port and polish the head, only inlet, enlarge the intake ports, gas flow it
3. do a 3 angle valve cut on the inlet valves, if possible do the decking for increase air flow
4. go with a 282/272 cam, this the lease aggrasive cam, too much, your engine will be a washing machine.
5. use the L-jetronic system, easy power gains on the distributer timing.dun need to use the chip, cos L-jet no chip, motoronic is much useless... less then 5hp with the chip
6. if can get a extractor -long length type, then better on the high rpm.
7. go with the e28 flywheel and clutch+pressure plate- better torque and clutch wont slip when doing drag- otherwise you will have a burned clutch.
8. go with a 260 getrag or a dogleg gearbox... dun use shot shift gearlever, it will ruin the box;
9. finally, final drive of 3.91 will be good.. very fast.. dun worry about the top end.. if the engine is balanced nicely, 7000rpm can stay..
10. others to play around, honed intake, enlarged trottle body, MSD ignition coil, e28 AFM, bigger capacity injectors..
All this, the engine will have 200++ horses...
cheers..
PostPosted: Fri Nov 21, 2008 4:37 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
aaa...the master has spoken:) so in total how much the total damage would be bro?
...balls must be upgraded to steel too:)
PostPosted: Sat Nov 22, 2008 3:22 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Good info bro. That' what we call sharing =)
cheers..
PostPosted: Mon Jan 12, 2009 6:12 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
I'm sorry...
Just wanted to spies this tread up a bit man...
Anyways, Was Planning to Convert My E30 M20b20 to a M20b27 high compression...
Which brings me...
Converting the Head to a M20b25 Motornic will be the best way...
or keep the L-Jet system...
But this conversion is hard to find parts that's about it...
PostPosted: Mon Jan 12, 2009 6:23 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Whoa Thanks for the info...
was actually doing the same thing too...
I did have problem just about doing the AFM and the motornic system...
Thanks man...
Ok here is my project for my engine:
Originally: M20B20
Modifying:
- Bore to 2.7L
- Use 2.5L Forge Steel Stroker
- 2.7 Forge Crank Shaft
- High Rev Cham-Shaft
- Convert the head to 6 Throttle...
(Most of it is base on the Hartge H35)
- Open Port Intake System
Gear Box:
Well i have not figure out the gear-box yet... just putting that aside 1st...
but now i got a getrag gearbox... dont know what model...
but for now just need to find a 4.1 LSD,
Plus i also have to change my rims to 16"...
I want both Horsepower & Handling in it...
So yeah... that's all about it...
nothing special...
Sorry bro highwaystar & aRRrgghh....
Did not meant to agonize you guys...
but i'm still collecting the parts 1st...
Just got my 2.5 light weight Stroker... Smile
So yeah... In time...
PostPosted: Tue Jan 13, 2009 2:48 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Thanks man...
Originally: M20B20
Modifying:
- Bore to 2.7L
Gear Box:
nothing special...
Well, this is sharing, anyway... good luck finding all those parts LOL!.. whatever you do, safety comes first. Brake System need to update, Chassis must be strengthen. For me, i'm not ready for these set ups.
Might have more patience, keep some money to upgrade straight swap S52
OR S14
mmmm.....
GOOD LUCK ON YOU CONVERSION ALEX!
PostPosted: Tue Jan 13, 2009 3:07 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
bro highwaystar, jangan la racun sampai macam tu. XD
PostPosted: Tue Jan 13, 2009 3:11 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
hahahaha... i'm now in the midst negotiating with fellows BMW performance guys for S14. kekekekekeke... worst have to use haltech ecu and good halfcut shop for AP....kekeke
bukan apa chris, i think s14 is good for chassis E30... our chassis pun bukan
kuat lagi daahhh...kekekeke. Also, i'm trying to be on the safe side.
This is my opinion jer. tapi kalau dapat syokkkkkk kekeke
UncleBuck
PostPosted: Tue Jan 13, 2009 6:14 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
haltech is gudd....s14?hmmm....an e6x shuld do the da trick....bolt on turbo.
PostPosted: Tue Jan 13, 2009 9:08 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
no need haltech, just opt for megasquirt, seach around. I saw its around Rm1.5k with tax from US. Its a full standalone .XD
PostPosted: Tue Jan 13, 2009 9:12 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
hahahaha... i'm now in the midst negotiating with fellows BMW performance guys for S14. kekekekekeke... worst have to use haltech ecu and good halfcut shop for AP....kekeke<--- haiii bro highway... melampau lampau dah nieee heheheh ghelerrr ahhhhhh... hebatt..
PostPosted: Tue Jan 13, 2009 9:14 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
very good xplanation mr puddycat..
PostPosted: Thu Jan 15, 2009 1:02 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
S52??? Waaahhhhh..... Thats my dream.Shown on you tube.
A very² fast car.And a m20b25 with stroker kit just 240km/h in 4.3sec.U want a speed somemore??? A stroker kit bolt on with turbo with Garrett T04Z turbine.I think thats better.Then we can go for sepang drag battle this march.Hehe..
Page 2 of 3
