Online Now [1307]:
Visitors: 1306
Today: 81435
Total: 31039546
E30 M20 L-Jetrionik Conver To Motoronik?
PostPosted: Mon Nov 17, 2008 7:14 am    Post subject: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Hey Malatians & Sifu-Sifu...
I have one crazy project...
That's is to defeat the M50 Singal Vanos Engine with an M20...
But anyways...
I was thinking to convert my M20 Engine To 6 Throttle...
Now using a E30 320i L-Jetronik..
Let's Say If I change my M20 to 6 Throttle...
Do i have to change my Engine AFM to MAF Sensor?
Which Technically Means Do I need to convert to M20 Motoronik?
But what's the ways to convert the M20 L-Jet to a Motoronik Engine?
Change the cylinder Head?
Change the Intake Manifold To the Motoronik Type?
Change ECU?
Please help me on my quest...
Thanks To All...
Alex, E30 SA
UncleBuck
PostPosted: Mon Nov 17, 2008 11:12 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
i think jetronic system itself is more potential than the motronic system.u can tweak and play around with more stuff.its like how proton's engine system last time werby d older batch of protons run on mitsubishi ecu and the newer batch runs on siemens.u can tweak more on the 1s runnin on mitsu ecus than the dull dead set siemens ecu.otherwise,i culd be wrong tho.
just my 2 scents.
my own ride runs on the 1st batch of the motronic system which is quite headache enuff.
PostPosted: Mon Nov 17, 2008 11:20 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Ah...
By the way...
How's the E36 Steering Conversion Going On...
UncleBuck
PostPosted: Mon Nov 17, 2008 4:51 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
not yet...havnt got the time yet & money..dude,y don u just rojak ur engine?put hantu inside la..
PostPosted: Tue Nov 18, 2008 1:31 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
m52 turbo=hantu
SimpleSoul
PostPosted: Tue Nov 18, 2008 3:20 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Sorry to hijack, just a quick question. would there any improvement on horsepower if i was to change the throttle body from a present M20B20 to M20B25?
PostPosted: Tue Nov 18, 2008 4:53 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
No... cuma increase engine reponse je bro..!!! Change the whole intake manifold to 2.5 model much better ar..!!! Just my 2cent lah... Wink
UncleBuck
PostPosted: Tue Nov 18, 2008 6:43 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
m52 turbo=hantu
dude,il kol u 1s im ready to collect aite..
SimpleSoul
PostPosted: Tue Nov 18, 2008 8:33 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
TQTQ
PostPosted: Tue Nov 18, 2008 1:03 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
UncleBuck, no worries, take your time.
PostPosted: Tue Nov 18, 2008 6:34 pm    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
what lah you guys...
Rojak a M50 in side an E30 is so common..
Have you guys ever thought of using you're original engine..
Improving it...
So that it can beat the M50 Engine..
I planned to Rojak M20, so that it's more has better responds..
not only that...
I planned to beat the M50 Engine...
I have a few planned to do up my engine...
One of it... is... (Cannot Tell)
PostPosted: Wed Nov 19, 2008 1:47 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
whatt larr this? you ask people to share.. and yet..aiiyoohh.
Okay al3dx, what you need to do with your M20 is
covert cannot tell then install cannot tell after that
your trailing arm cannot tell. You will reach about cannot tell.
Manifold have to use cannot tell with cam shaft cannot tell.
Taddaaa... you got one mean machine!
Overall your budget is around cannot tell.
Have fun! hahahahahahhaa Embarassed Embarassed Embarassed
PostPosted: Wed Nov 19, 2008 2:22 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
stroke ur m20 to 2.8 . or 3.0 . end of story .
u might ...might beat an m50 .
good luck .
UncleBuck
PostPosted: Wed Nov 19, 2008 3:30 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
good luck .
i 2nd this..this is wat i meant putting in or rojak hantu la...
PostPosted: Wed Nov 19, 2008 3:39 am    Post subject: Re: E30 M20 L-Jetrionik Conver To Motoronik? Reply with quote
Dewd, next time don't start a thread if you're not sharing anything. Asked so many questions end up want to keep the answers to ur self.
This is an Online Community NOT a CallCentre or Helpline where u can get answer by NOT contributing anything, try to learn how to mix around.
Improving it...
not only that...
