Online Now [2634]:
Visitors: 2633
Today: 53215
Total: 30453746
m20b23 jerking
apanz
PostPosted: Sat Nov 08, 2008 4:02 pm    Post subject: m20b23 jerking Reply with quote
Allo,
My E30 start jerking when i try to accelerate and after shift gear..enjin macam nak mati tapi tak.. cuma macam semput-semput..sekejap ada pickup sekejap tak ada..RPM langsung x boleh cecah 3K..drop gear pun sama juga..
So sifus out there please help, what is possible problem? Cannot stand anymore just can speed last 90 kmh only..kancil potong senyum saja Very Happy
PostPosted: Mon Nov 10, 2008 1:17 am    Post subject: Re: m20b23 jerking Reply with quote
jerking?
Ikut sequence, yang penting rotor arm.
1. Check rotor arm (tukar baru atau get a good 2nd hand)
2. Plugs cable and spark plugs (check, kalau kotor tukar all 6)
3. Plugs cable leaking current.
4. Check fuel filter
5. Check fuel Pump
PostPosted: Mon Nov 10, 2008 2:46 am    Post subject: Re: m20b23 jerking Reply with quote
could be a vacuum leak or ur AFM needs some cleaning .
just a guess
apanz
PostPosted: Mon Nov 10, 2008 11:49 am    Post subject: Re: m20b23 jerking Reply with quote
jerking?
5. Check fuel Pump
just a guess
Thanks bro highwaystar and wks79.
Actually the problem happened after i service the car (changed spark plugs, engine oil and oil filter). Maybe my plug cable 'koyak' or as bro highway said rotor arm worn out. Will fixed it as soon as possible.
PostPosted: Mon Nov 10, 2008 2:57 pm    Post subject: Re: m20b23 jerking Reply with quote
just curious whether the check engine light on? u said u just serviced the car so guess worth checking the O2 sensor, who knows the mechanix might accidentally unplugged it while pulling the jack:) just a thought though:)
anyways u might wanna check these in sequence kekekke...
1. fuel filter
2. plugs
3. cables
4. fuel pump
5. vacuum hose
6. afm
PostPosted: Mon Nov 10, 2008 5:28 pm    Post subject: Re: m20b23 jerking Reply with quote
you can always test the O2 sensor by unplugging it and take a drive. If there's a difference, change the thing.
my 2 cents
PostPosted: Tue Nov 11, 2008 3:07 am    Post subject: Re: m20b23 jerking Reply with quote
O2 sensor on Jetronic? got meh? so far that i know only motronic.
PostPosted: Tue Nov 11, 2008 3:57 am    Post subject: Re: m20b23 jerking Reply with quote
oppss, didnt notice its jetronic engine. Sorry!
apanz
PostPosted: Tue Nov 11, 2008 11:41 am    Post subject: Re: m20b23 jerking Reply with quote
1. fuel filter
2. plugs
3. cables
4. fuel pump
5. vacuum hose
6. afm
hehe bro jeembo, my car got no 02 sensor la..no check engine light warning but sometimes when revving the engine like no power, press pedal to the floor but engine seem want to die..will send to workshop in this weekend..Will update soon.
anyway thanks for your advice.
PostPosted: Tue Nov 11, 2008 5:27 pm    Post subject: Re: m20b23 jerking Reply with quote
Bro... masa lu revving engine mcm nk mati kn, ada tak asap itam kuar kt ekzos...? Rolling Eyes
apanz
PostPosted: Thu Nov 13, 2008 11:41 am    Post subject: Re: m20b23 jerking Reply with quote
tak..tak kuar asap apa pun..
PostPosted: Thu Nov 13, 2008 12:31 pm    Post subject: Re: m20b23 jerking Reply with quote
check the air flow meter. get it calibrated properly.
PostPosted: Thu Nov 13, 2008 3:25 pm    Post subject: Re: m20b23 jerking Reply with quote
how to calibrate ah???oso where can check for TPS faulty or not?
PostPosted: Fri Nov 14, 2008 2:12 am    Post subject: Re: m20b23 jerking Reply with quote
if im not mistaken, they use the o2 machine to test it and the TPS can be adjusted below the throttle body.
apanz
PostPosted: Sat Nov 15, 2008 12:16 pm    Post subject: Re: m20b23 jerking Reply with quote
Sent the car to my mech...he just changed fuel filter and wallaaaa my car can rev again Very Happy Thanks all for the advice..
