Online Now [2404]:
Visitors: 2404
Today: 40283
Total: 30440814
BMW Models Offset (ET) and PCD Information
PostPosted: Fri Sep 12, 2008 8:10 pm    Post subject: BMW Models Offset (ET) and PCD Information Reply with quote
PCD & OFFSET INFORMATION
MINI (NEW)
PCD 4x100 OFFSET 35 CENTER BORE/CONE 57.0
E30
PCD 4x100 OFFSET 15-25 CENTER BORE/CONE 57.0
E30 MOTORSPORT
PCD 5x120 OFFSET 18-20 CENTER BORE/CONE 72.5
E36, E46, Z3
PCD 5x120 OFFSET 35-42 CENTER BORE/CONE 72.5
E31, E32, E34, E38
E39
PCD 5x120 OFFSET 18-20 CENTER BORE/CONE 74
Please do add for other models
PostPosted: Sat Sep 13, 2008 6:38 pm    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
for E30, those who are having bottlecaps, their offset is 38.
PostPosted: Tue Sep 16, 2008 5:31 pm    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
is 38? i tot 35..
for E30...offset vs width
offset 35 = 6jj
offset 30 = 6.5jj
offset 25 = 7jj
PostPosted: Tue Sep 16, 2008 5:38 pm    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
if you guys wondering what's the meaning of ET.
ET which stands for EinpressTieffe = Offset
PostPosted: Tue Sep 16, 2008 6:48 pm    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
bro highway, can also do a sticky on tyre & wheel combination calculator aaa? thanks!
rzonealley
PostPosted: Mon Oct 20, 2008 1:40 am    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
orangebmw wrote:
is 38? i tot 35..
offset 35 = 6jj
offset 30 = 6.5jj
offset 25 = 7jj
if 8jj is the offset should be 20?
PostPosted: Mon Oct 20, 2008 12:28 pm    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
yes..that is perfect combination for E30...
rzonealley
PostPosted: Mon Nov 03, 2008 1:25 pm    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
i think to be exact et38 is for those e30 with solid front disc.
my e30 using rim with et38 with original setup disc.
when i convert to another model (i dunno what model) which got ventilated
disc with girling brake i cant fit my rim anymore. the rim stuck at the spoke.
jackyhong
PostPosted: Sat Nov 08, 2008 2:55 am    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
E36, E46, Z3
E31, E32, E34, E38
Q: can E34 use E46 rims????
PostPosted: Mon Nov 10, 2008 1:10 am    Post subject: Re: BMW Models Offset (ET) and PCD Information Reply with quote
can.. but offset masuk dalam kaw. 20mm...
