Online Now [1280]:
Visitors: 1280
Today: 112608
Total: 31070719
E30
creezchan
PostPosted: Wed Oct 08, 2008 3:02 pm    Post subject: E30 Reply with quote
I like the E30 coupe. I was advised by some khabar angin to search for the year 91/92 and above because it is made out of galvanized steel rather than the older ones which are eacy to "karat". apakah pendapat audien audien sekalian?
PostPosted: Wed Oct 08, 2008 4:48 pm    Post subject: Re: E30 Reply with quote
very true! unless kereta sudah kena bang...then karat will lurk ehhehe but then its not easy to get the coupe bro for the last model, mostly i saw lotsa sedans...any sifoos here can help our fren here:) but if ur balls are made of steel than easier for u to get a coupe bro:)
creezchan
PostPosted: Wed Oct 08, 2008 5:10 pm    Post subject: Re: E30 Reply with quote
y balls have to be made of steel? pls teach me sifu jeembo
FerMan
PostPosted: Wed Oct 08, 2008 11:08 pm    Post subject: Re: E30 Reply with quote
Means kalau you berani drive kereta coupe karat ler.
PostPosted: Thu Oct 09, 2008 3:41 am    Post subject: Re: E30 Reply with quote
actually galvanised body is 89 and above and the last model is 91 for E30. 91 and above is E36.
You can dream to get E30 Coupe year 89 and above because auto bavaria tak bawa masuk 2 pintu... most of available coupe model is year 84 - 87. Kalau buleh dapat pun imported model on which susah nak dapat...
mmm... i suggest get E36... cun wei! heheheh
PostPosted: Thu Oct 09, 2008 5:08 am    Post subject: Re: E30 Reply with quote
actually abang reinier the last e30 4 door was still produced in 92 by Auto Bavaria ie Suresh 's e30, and also one of ah foo's customer.
over seas up till 93 they still produce the e30 convertibles throughout the early stages of the e36 which started production in 91.
but chan san, nothing is impossible, u can still find a coupe post 88....just need alot of patience and moolah....
but another word of caution, doesnt mean its post 88, u wont have rust,
i have seen a 91 model e30 4 door rusting to glory. so what ever car u buy, whichever year, still insist on jacking up the car to see the undercarriage and the firewall...
PS : get a 36, higher chance of the car surviving the rust revolution.(however i have also seen some e36s which are rust buckets, due to prior accidents and welding jobs below par)
PostPosted: Thu Oct 09, 2008 6:22 am    Post subject: Re: E30 Reply with quote
Eerrrkk.. suresh is 92 ehh?.. wahh now creez you and i know oledi..kekeke
kalau dah besi.. rust memang buleh punya... only time factor...betul tak?
heard around technic of welding also counts.. some use electric and some use gas.. also weld using copperweld and buttwelding, arc welding etc... if the old owner use normal welding (maybe to fix tiny thing)... it also prone to rust, thus all those tiny metal molecules is not solid and exposed easily to O2 and moisture.. the rust start spreading.
if the body is full galvanised but improper welding component, mesti berjangkit punya.
best of luck!
PostPosted: Thu Oct 09, 2008 6:59 am    Post subject: Re: E30 Reply with quote
and then gunalah anti rust jenis hammerite...kurust or rust bullet...5 years guarantee karat won't come back...its not to cure the rust but to prevent it. i have it coated to my E30 coupe 1984 model kekekke
PostPosted: Thu Oct 09, 2008 9:41 am    Post subject: Re: E30 Reply with quote
Found this. Kelakar la this seller;
Price: RM 9 500 Reg. year: 1984 Mileage: 250 000 - 299 999
convert to 325 (A), not endorsed yet, custom letter still searching by owner( either have or not, terrible la this owner), electric seat (from Alfa),good condition, asking RM9,500.00 nego. call sany 019-3688338
creezchan
PostPosted: Thu Oct 09, 2008 12:33 pm    Post subject: Re: E30 Reply with quote
OMG how did i not catch that. sorry blur, or maybe pravin blocking me, cant see.
want to buy any BMW pun must have dough man. buy E30 now oso suffer later, parts running out. abang reineir sendiri buat store room khas for E30 lol. i wud probably take a little while longer b4 i get my BMW la. masih muda lagi.
aRRrgghh.. (lol i duno ur name) custom letter means tat car bawa dari atas laut ke?
PostPosted: Fri Oct 10, 2008 6:11 pm    Post subject: Re: E30 Reply with quote
It's not the car. It's the engine that the owner converted.
creezchan
PostPosted: Sat Oct 11, 2008 2:38 am    Post subject: Re: E30 Reply with quote
ooo ok ok
saintdastar
PostPosted: Fri Oct 24, 2008 9:29 am    Post subject: Re: E30 Reply with quote
bmw stupid car la! buy mercedez! ha ha ha
Classics are BUILT, not BOUGHT.
/// 01
