Online Now [1418]:
Visitors: 1418
Today: 142383
Total: 31100494
E30 timing belt cost
lempeng7
PostPosted: Wed Oct 08, 2008 3:45 pm    Post subject: E30 timing belt cost Reply with quote
Hi all,
Mintak tolong sifus2 sekalian,
I just bought an E30 just before raya. The problem is I tak tau history of the car, so plan nak wat preventive maintenance into the car mcm check timing belt ker, radiator , tukar minyak itam dan dll.
So I nak tanyer... agak2 baper total cost kalo nak tukar timing belt termasuk belt2 yg lain.? (As I know, E30 guna belt, x guna chain..betul ker?)
any recommended workshop?..kalo buleh area Puchong/Seremban/Nilai....
time kaseh...
PostPosted: Wed Oct 08, 2008 4:35 pm    Post subject: Re: E30 timing belt cost Reply with quote
very cheap like hell bro! cheaper than proton. i've changed all my beltings but forgot the price but trust me its dirt cheap. timing belt alone below rm80, bought at Innerpower jln ipoh last June. i bought beltings, a pair of hub bearings, longshaft coupling, gearbox seals, door handle bezel, door card clips everything under RM600.
PostPosted: Thu Oct 09, 2008 3:36 am    Post subject: Re: E30 timing belt cost Reply with quote
Okay, if you just got your car, always change timing belt and it is compulsory. Words from the seller kadang2 buleh pakai tapi tak banyak buleh pakai.
Timing belt cost RM70, to do that you also must change oil seal and bla2... bukan apa..since dah bukak.. might aswell change the rest. this to jimat workmanship. last i done around RM680 this include
Timing belt
Aircond belt
Power steering belt
Alternator belt
Oil seal
timing bearings
and workmanship
PostPosted: Thu Oct 09, 2008 7:00 am    Post subject: Re: E30 timing belt cost Reply with quote
haaa i told u...its cheap wooo...hehehe
lempeng7
PostPosted: Fri Oct 10, 2008 1:40 am    Post subject: Re: E30 timing belt cost Reply with quote
Thank you Master Sifus Highwaystar,
To change all the parts, I need to order first the parts or just can walk-in into workshop and then they can get the parts immediately?
One more thing, how much the cost for speed sensor? My odometer is not functioning. Assume that the speed sensor is 'out' already...
p/s....I'm still dont know where should I go to do the maintenance....worry if I go the wrong workshop.
PostPosted: Fri Oct 10, 2008 4:00 am    Post subject: Re: E30 timing belt cost Reply with quote
it is best for you to buy the 'barang' yourself, some workshop they mark-up 20% to 30% of part price reasoning, they willing to give warranty. What i think that is bulls..t, most of parts got defects 2/100 and most parts supplier gave their inhouse warranty.
as for your speedometer, are you sure that the sensor is out? i suggest get complete set and test first before buy. average price is RM300
cheers!
PostPosted: Fri Oct 10, 2008 6:25 am    Post subject: Re: E30 timing belt cost Reply with quote
Eh highway, is it necessary to change all these too?
Aircond belt
Power steering belt
Alternator belt
Oil seal
timing bearings
I'm goin to change my timing belt soon, but didn't notice these others you mentioned.
1st Division quoted RM160 I think for timing belt kit, I'm not sure what other belts/parts are included in their kit. That is OEM, the original BMW kit is RM260 I think.
PostPosted: Fri Oct 10, 2008 9:29 am    Post subject: Re: E30 timing belt cost Reply with quote
Aircond belt
Power steering belt
Alternator belt
Oil seal
timing bearings
timing belt kit (i guess) it consist of timing belt, oil seals (4 units) and 'O' Ring.. but not sure of timing bearing.. timing bearing itself cost around RM75. Better call them and re-confirm.
If you plan to change timing belt, its better to change the oil seal bearing ('O' Ring) Oil seal and bearing also because it is part of the timing assembly. As for the other beltings like power steering, aircond etc.. thats depends on wear and tear.
Please do check with them what parts include in the Timing belt kit.
Cheers
PostPosted: Sun Oct 12, 2008 4:21 pm    Post subject: Re: E30 timing belt cost Reply with quote
OK good, thanks dude. Wink
PostPosted: Mon Oct 13, 2008 11:46 am    Post subject: Re: E30 timing belt cost Reply with quote
good info enche highway... plan nak tukar timing belt jugak 1 day. tima kasih jugak kepada yang bertanya... hehehe
lempeng7
PostPosted: Tue Oct 14, 2008 2:30 pm    Post subject: Re: E30 timing belt cost Reply with quote
Thank you very much to all sifus.
Really appreciate your kind advise.
BTW, where can I get all the parts with reasonable and original parts?
thnx...
MKMD428
PostPosted: Fri Oct 17, 2008 8:30 am    Post subject: Re: E30 timing belt cost Reply with quote
revised....
total cost + workmanship utk tuka timing belt set complete sebenarnya berapa ye?
PostPosted: Fri Oct 17, 2008 9:05 am    Post subject: Re: E30 timing belt cost Reply with quote
since timing belt kit is RM160, workmanship around RM80 - 100
so better have budget RM300.
MKMD428
PostPosted: Fri Oct 17, 2008 2:50 pm    Post subject: Re: E30 timing belt cost Reply with quote
thanks bro............senangla klu cenggitu...
opsss satu lagi...since me never use a continental car...so the question would be....normally on what mileage should we must change the timing belt? ..mcm kete jepun jugak ke?
PostPosted: Thu Oct 23, 2008 4:08 pm    Post subject: Re: E30 timing belt cost Reply with quote
Just called First Div today to get a quote since I plan to change soon.
Timing belt (original BMW) - RM 210
Timing belt (OEM) - RM 70
Bearings, the small one RM 50, the bigger one RM 55.
But Munich Auto selling both together for RM 90.
Oil seal is RM 35.
