Online Now [1140]:
Visitors: 1140
Today: 145044
Total: 31103098
car vibrate
MKMD428
PostPosted: Tue Aug 19, 2008 3:54 pm    Post subject: car vibrate Reply with quote
kawan2 tlg............
my car is a 4 door e30 with m40 engine. the problem is...bila tekan pedal minyak utk laju je msti gegar...gegar kuat..
what causes this? drivetrain? suspension? tlgla daku......
PostPosted: Tue Aug 19, 2008 4:51 pm    Post subject: Re: car vibrate Reply with quote
do you feel the vibration even when you rev at idle?
rocco_siffredi
PostPosted: Tue Aug 19, 2008 6:53 pm    Post subject: Re: car vibrate Reply with quote
tayar allignment ?
PostPosted: Wed Aug 20, 2008 4:11 am    Post subject: Re: car vibrate Reply with quote
Probably cause
please check in stages.
0. BAD balancing (when reached certain speed)
1. Center bearing (when car is moving and acceleration)
2. Long Shaft (gearbox to rear axle - stump sound and vibrate)
3. Dry Shaft (rear axle to rear wheel)
4. Gearbox mounting
5. Lower arm (this sometime vibrate when brake)
6. Disc brake wobble (this happen while braking)
PostPosted: Wed Aug 20, 2008 5:15 am    Post subject: Re: car vibrate Reply with quote
i suspect the centre shaft bearing or the guibo since he said when accelerating..hmmm...must check
MKMD428
PostPosted: Wed Aug 20, 2008 6:58 am    Post subject: Re: car vibrate Reply with quote
not happening when revving in idle.......
PostPosted: Wed Aug 20, 2008 7:10 am    Post subject: Re: car vibrate Reply with quote
VIBRATION DAMPER ON YOUR DRIVESHAFT...RM 4++
03 TORSIONAL VIBRATION ABSORBER 1 2611143425
www.realoem.com/bmw/sh...g=26&fg=10
PostPosted: Wed Aug 20, 2008 12:42 pm    Post subject: Re: car vibrate Reply with quote
dont forget to check long shaft coupling
MKMD428
PostPosted: Thu Aug 21, 2008 2:24 am    Post subject: Re: car vibrate Reply with quote
thanks bro.... more specific details..
the car start vibrating on the rear left side on and occurs on the 4th gear and above when the rpm reaches 2k and above with speed 60km/h and above
PostPosted: Thu Aug 21, 2008 2:48 am    Post subject: Re: car vibrate Reply with quote
SAME THING HAPPENED TO MINE.the damper comes loose as you speed up and has the expansion effect hence the vibration and gravity pull effects the rubber as you go into a turn....much like tying a ball with a string onto your driveshavt and driving fast.....go under your car and check nn see if ithe rubber thiny has come lose as in the realoem part no 3 above
MKMD428
PostPosted: Thu Aug 21, 2008 7:45 am    Post subject: Re: car vibrate Reply with quote
thanks bro...........might bring my car to a wheel shop..
MKMD428
PostPosted: Thu Aug 21, 2008 4:26 pm    Post subject: Re: car vibrate Reply with quote
just came from wheel shop.........
found out that all my 16" rims bengkok...especially the rear ones...bengkok gila2....F##k!!!
PostPosted: Thu Aug 21, 2008 4:51 pm    Post subject: Re: car vibrate Reply with quote
get 15" rims...u'll be much happier XD
PostPosted: Fri Aug 22, 2008 2:43 am    Post subject: Re: car vibrate Reply with quote
hahhahha banyak simple laaa.....saya ada rim 15 ats mau???
MKMD428
PostPosted: Sat Aug 23, 2008 2:45 am    Post subject: Re: car vibrate Reply with quote
thanks for the offer bro......
i still want 16"... hehehe
