Online Now [1064]:
Visitors: 1063
Today: 180088
Total: 31120620
need help.. my e30 idling kacau bilau...
PostPosted: Tue Jul 08, 2008 7:13 am    Post subject: need help.. my e30 idling kacau bilau... Reply with quote
to any sifu could help me here.. wa punya engine 6 silinder idling dia mcm tak betul la.. tetiba je tatau apasal.. mcm turun naik idling dia.. saya ada sertakan pic sekali hanya nak bertanya.. adakah disebabkan sensor ini? yg dalam bulatan merah ni? sensor ni terletak dibawah intake manifold
PostPosted: Tue Jul 08, 2008 8:05 am    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
sampai terkehel leher aku tengok gambar ko..heehheeh... mmm pelik betul bentuk die, mungkit hose cabut kot. itu idling valve lah.. you punya Ljet kan?
PostPosted: Tue Jul 08, 2008 8:16 am    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
ada hantu atau ada hose yang bocor..atau ICV anda stuck!
PostPosted: Tue Jul 08, 2008 8:42 am    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
Sometimes, it's not necessary the (Idling Check Valve) ICV. It might be ur AFM. Check if the 'butterfly' is smooth to flap. Check the hoses too. The harden hoses can be the culprit too. Good luck.
PostPosted: Tue Jul 08, 2008 9:38 am    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
sorry to all of u sebab pic tu.. nak amek sempit sgt..tu yg jadi cenggitu tu pic tu... hehe sorry bro highway.. thanks for the advise.. sebab sebelom ni ok je engine tu running.. sejak aritu wa gatal tgn bukak penutut rocker cover tu pi ganti dia punya gasket getah pastu cat penutup tu kaler itam bila pasang balik terus jadik idling gile mcm tu.. tatau mana 1 yg terlupa pasang balik or something had been broken.. itu yg terperasan 1 brg dok tergantung(mcm dlm pic attachment) tu adalah masalahnya.. err bro highway Ljet tu apa? hehe err den kerete bmw ni mmg zero... kete jepun wa tau..
PostPosted: Tue Jul 08, 2008 5:59 pm    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
cuba ko check balik mana la tau ikatan rocker cover tu tak ketat atau gasket baru tukar tu blown sbb, kekadang engine M20B20 ni sensitip...ko pakai torque range tak masa ikat rocker cover tuh? ikatan dia 7ft-lbs/9Nm kalo tak silap...aku penah jadik dulu, tp aku tukar engine terus kekekeke...
PostPosted: Wed Jul 09, 2008 3:18 am    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
bro jeem.. masa ikat screw tu mmg pakai torque range tgk pomen tu buat tapi tak pasti berapa pulak dia set.. sebab setakat ni dia buat engine bmw ok je.. takde customer yg bising or kata bad reputasi.. engine kete saya tu baru je tuka tu.. baru endorse pun.. setakat ni bawak sedap lagi drpd segi pick up laa.. cuma bila berhenti je dia mcm bergegar.. sebab sebelum ni ok je.. mcm seolah olah engine tak start je.. tetiba skang ni jadi mcm ni.. rasa mcm nak nangis je..
miedl
PostPosted: Sun Jul 27, 2008 3:04 pm    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
penangan bongkok udang la tu..
tapi kira ok la tu..hat 2j nu dok paking ja..nak tuggu jadi transforme ja tu...aku pun taktau apa prob keta hang ni..
UncleBuck
PostPosted: Tue Aug 26, 2008 6:48 pm    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
mayb rotor kot...
mcdy
PostPosted: Sun Aug 31, 2008 2:40 am    Post subject: Re: need help.. my e30 idling kacau bilau... Reply with quote
tukar engin jer kc. heheheheheh
