Online Now [1643]:
Visitors: 1643
Today: 113311
Total: 31071422
wheel bearing n brakes...
a-boo
PostPosted: Sun May 25, 2008 5:47 am    Post subject: wheel bearing n brakes... Reply with quote
how much for a wheel bearing n also calliper repair kit guys? my car starts to vibrate above 80km/h, vibrates when i brake, it moves to the side mcm lari alignment tapi dah buat alignment... whats the masalah problem? Sad
chili39
PostPosted: Sun May 25, 2008 6:17 am    Post subject: Re: wheel bearing n brakes... Reply with quote
check ur brake disc it might thin already so when u brake the car vibrates.cliper repair kit is about rm70 for 1 pair,wheel bearing is about rm170 per pcs & disc rotor is about rm120 per pcs.
PostPosted: Sun May 25, 2008 8:57 am    Post subject: Re: wheel bearing n brakes... Reply with quote
Better get it done ASAP bro. Safety is No. 1!
a-boo
PostPosted: Sun May 25, 2008 3:44 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
definately... one more question... my brakes tak makan sangat why ah? just recently change brake... how much to convert to rear disc brakes? mine is still drums...
www.teameighth.com
Sympathy Towards Gravity
tyk3
PostPosted: Sun May 25, 2008 4:06 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
a-boo,bro here are the prices as far as i can remember...
1. wheel bearing
front RM86 each (aprox)
rear RM180 each (aprox)
2. calliper kit RM70 (aprox)
3.Disc
Brembo (vented) RM120 each
4.Brake Pad
as for your brakes not working properly,it could be 1 of so many probs la...
can be your brake master pump,servo etc.
if you need to know where to go and get your items call me la bro.
Ferodo RM130 p/pair
e30's rule!
PostPosted: Sun May 25, 2008 4:12 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
Yup bro. One way of getting good braking is to convert ur rear drum. I've got mine fer RM500. Other than that, upgrade to steel braided hose, convert ur brake servo (from E32) and get a good pads. Good luck =)
a-boo
PostPosted: Mon May 26, 2008 4:16 am    Post subject: Re: wheel bearing n brakes... Reply with quote
Rm500 including installation? where to do ah bro? what rear disc brakes u use? long shaft need to change? total cost? my brakes are really screwed man... Sad
www.teameighth.com
PostPosted: Mon May 26, 2008 5:00 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
RM500 only fer the rear disc + trailing arm. Workmanship around RM50 only (friends workshop - now tutup kedai). But make sure u get the handbrake cable or u can get it brand new. Bought it from a forumer too. I guess u can get it done at any workshop. I'll look around fer u if I can find any =)
PostPosted: Mon May 26, 2008 7:01 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
if brek tak makan, please change the brek servo to E32 double layer. E30 is well known for its brek. Rear Disc conversion is another good investment as well.
PostPosted: Tue May 27, 2008 4:19 am    Post subject: Re: wheel bearing n brakes... Reply with quote
How much E32 servo?? Any mod need??
PostPosted: Tue May 27, 2008 8:09 am    Post subject: Re: wheel bearing n brakes... Reply with quote
Chris ahhh... did you upgrade to E32 servo already? i remember you also looking for it.
a-boo
PostPosted: Tue May 27, 2008 1:24 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
how much is the servo? tapi tempted nak tukar disc brek... heheh
www.teameighth.com
PostPosted: Tue May 27, 2008 2:55 pm    Post subject: Re: wheel bearing n brakes... Reply with quote
Disc break first bro. Go fer it!
